20 Most Recent Canon imageCLASS MF3240 All-In-One Laser Printer Questions & Answers
4answers
Have Canon MF3200 (priner, fax, scanner) PC will
Hi, It's driver related problem, to be solved, please visit this webpage and follow the instructions: Driver Update Software for XP Vista 7 8. enjoy
11/17/2021 8:13:30 PM • Canon imageCLASS... • Answered on Nov 17, 2021
7answers
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
11/17/2021 8:13:14 PM • Canon imageCLASS... • Answered on Nov 17, 2021
I want to know if the Canon imageCLASS MF3240 is a postscript printer? Other question is there any way for the driver to work under ubuntu 12.04.5?
do you have instruction manual ? you may be able to print from the printer a settings summary which may show the language the printer is expecting ./ there may be a way for a windows driver to work in ubuntu it is done by either finding a ubuntu driver for the printer (which seems really hard to find) or mucking around using ndiswrapper utility to try and manipulate a driver to work in ubuntu. sourceforge.net/projects/ndiswrapper/
10/26/2015 11:34:17 AM • Canon imageCLASS... • Answered on Oct 26, 2015
2answers
Canon MF3240 firmware update failure
YOU THEN NEED TO REINSTALL IT BECAUSE YOU CANT ROLL BACK THE FIRMWARE
9/24/2015 2:22:20 PM • Canon imageCLASS... • Answered on Sep 24, 2015
2answers
Cannot find driver/software for my dusty Canon imageCLASS MF3240 on mac OS 10.7 Lion?
There is no driver for your printer to work with OSX. It was for Windows OS only. AND Apple does not support this particular model either.Link below list support printers by Apple OSX>http://support.apple.com/kb/ht3669
12/30/2014 12:32:45 AM • Canon imageCLASS... • Answered on Dec 30, 2014
5answers
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
6/12/2013 7:35:55 PM • Canon imageCLASS... • Answered on Jun 12, 2013
My computer is connect to my canon imageclass mf3240 by usb and already installeddriver and software by canon, what I need is to scan the form from printer to my laptop email or file
I had the same problem and I just plugged my laptop into the printer and it worked. Try to email it to yourself or save it on a memory stick and plug it into your printer.
3/27/2013 5:36:37 PM • Canon imageCLASS... • Answered on Mar 27, 2013
2answers
Error message will not go away
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
5/22/2012 12:10:07 AM • Canon imageCLASS... • Answered on May 22, 2012
2answers
I am trying to install
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
5/22/2012 12:08:43 AM • Canon imageCLASS... • Answered on May 22, 2012
2answers
I have a Conon MF3240
It is only working on 32 bit PC, not 64 bit.
5/22/2012 12:04:21 AM • Canon imageCLASS... • Answered on May 22, 2012
Canon imageCLASS MF3240 All-In-One Laser Printer Logo
Popular Tags
83 questions posted
old marine
old marine
Ekse
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
canon mf3200 priner fax scanner pc
  • Office Equipment & Supplies
