20 Most Recent IBM eServer BladeCenter HS20 Questions & Answers
Installing windows 2003 server on IBM bladecentre
shell32.dll file is very important windows system files.It control all users grapgical settings, icons, anything related to graphic user interface of the Operating system.If shell32.dll cannot be copied during installation,the system never gets to GUI mode.Try using a New CD/DVD.it will solve your problem.
12/23/2009 7:21:22 AM • IBM eServer... • Answered on Dec 23, 2009
IBM x3650 M4 reset administrator password in BIOS
In some BIOS password configurations , you can set a user password and an administrator password . Sometimes the user password lets the computer boot but won't let you in the BIOS setup, but on other occasions, the user password will do both.
7/19/2021 6:57:42 PM • IBM Computers &... • Answered on Jul 19, 2021
I have a IBM personal computer Platinum III When I turn on my computer it starts normally but after that on my screen appears a text that says "System Error: tastiera Blocked" And after I can't continue to boot and it shows on my screen a error without a code...What should I do??
Tastiera indicated that you have a keyboard problem. Most desktops can't run without a working keyboard. (You need the keyboard connected and working during the power-on self test, POST.) Currently the motherboard can't communicate with the keyboard. What is the model number for your computer? I don't recall a Platinum III, just a Pentium III. Is it a laptop or a desktop? What type of keyboard do you have (USB or PS/2 connector) or is it the built-in one of a laptop? Are you using some sort of converter/adapter for the connections? The USB to PS/2 converter for a mouse does not work with a keyboard. There are some USB to dual PS/2 converters available. However, they don't work with with all motherboards. What OS is installed on the system? Try a different keyboard. (You should try a PS/2 keyboard if the system has PS/2 ports. If the OS is older than Windows 98 v. 2, then the USB ports are even more likely to not see the keyboard in POST.) If you use a USB keyboard, try different ports. If possible, make sure that the keyboards work on other machines. If it does, then I recommend replacing the system. The Pentium III is a ~20 year old CPU. That's certainly old enough to have major failures. I hope this helps. Cindy Wells
1/30/2021 3:36:22 PM • IBM Computers &... • Answered on Jan 30, 2021
I am trying to restore my IBM 600E Thinkpad. I
Hi blue_sky_day,
While googling on the net, I found something related to your problem at this web site: http://www.howtomendit.com/answers.php?id=12813
There are explained many things about your IBM 600E Thinkpad, you will have to read it and see if you can solve your trouble.
Yours sincerely.
7/11/2020 1:28:12 PM • IBM Computers &... • Answered on Jul 11, 2020
2answers
Hello, how do i change the font size on the screen in ibm lotus organizer 6.1
RTM , on the APP, be first.. good luck this old, finding it. google all day?
2/22/2020 1:52:07 PM • IBM Computers &... • Answered on Feb 22, 2020
Connecting boot devices and adapters
Connecting boot devices and adapters - IBM server with 2008 r2 server
10/10/2019 6:18:46 AM • IBM Computers &... • Answered on Oct 10, 2019
I have an IBM QuietWriter7 which does'nt work very well. After a few stikes, there are code lights and beeps. The code lights are three : capital, 2inx and double interline. What does it mean?
find the service manual yet>? it is type writer opted printer from year 1984 good luck finding manual , try googling , but 1984 is very very old.
10/7/2019 10:33:46 AM • IBM Computers &... • Answered on Oct 07, 2019
2answers
How do NSF to PST converter
Download NSF to PST File Converter tool to convert NSF data into PST file format. This NSF to PST converter Software nicely convert NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file. More Info :- NSF to PST File Converter
9/25/2019 4:38:06 AM • IBM Computers &... • Answered on Sep 25, 2019
IBM system halted, no memory could be configured, how can i solved this problem
Bad memory stick, possibly. Or maybe bad motherboard. try different memory, and try swapping to different slots.
7/23/2019 6:18:52 AM • IBM Computers &... • Answered on Jul 23, 2019
Kumon math solution level H23
dfqaef
7/11/2019 5:12:24 PM • IBM Computers &... • Answered on Jul 11, 2019
I would like to find a repair manual for an IBM QuietWriter 7 model
Check IBM website. if not try manuals.com Mike
5/19/2019 11:42:09 PM • IBM Computers &... • Answered on May 19, 2019
Powerlights and hard drive lights come on on my T22, but there is no power to my monitor.
Have you tried using an external monitor to make sure the video is working on the new motherboard?
5/8/2019 6:08:42 AM • IBM Computers &... • Answered on May 08, 2019
Where can I find drivers for IBM Deskstar 34GXP DPTA-371020 hard drive?
I am not an expert in such things but I think if you use a widely available adaptor that will power the old hard drive and provide usb connectivity your Windows 7 should be able to read and allow you to move files, as long as the old drive and the WIN 7 are both 32 BIT (or 64)...
4/27/2019 9:12:11 AM • IBM Computers &... • Answered on Apr 27, 2019
2answers
Playing mp4
hi, try using a vlc player to play, if you dont have download it from here: http://vlc-media-player.en.softonic.com/download
4/25/2019 9:51:10 AM • IBM Computers &... • Answered on Apr 25, 2019
How do i get a driver for a 2005 IBM thinkvision 9419 hx7 monitor for windows 10
Win10 should auto-detect it; so it should need a driver from it manufacture. Assuming the monitor is properly functioning, and if you are still having problems: 1) Use the most up-to-date connection such as HDMI, DVI, or Display Port 2) Then with the monitor connected, force a Windows update. 3) Make sure the display adapter's resolution matches one of the monitor's supported resolutions.
12/19/2018 8:10:31 PM • IBM Computers &... • Answered on Dec 19, 2018
2answers
I want to reset my computer so i can sell it
You're wrong that is not reset it is format.. Take to any windows dvd like windows 7, 8, 10. And install in reboot with the settings of BIOS and follow instructions..
11/26/2018 4:54:22 AM • IBM Computers &... • Answered on Nov 26, 2018
IBM eServer BladeCenter HS20 Logo
1 questions posted
Top IBM Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Computers & Internet
Most Popular Question
installing windows 2003 server ibm
  • Computers & Internet
