20 Most Recent
Olympus Om Auto Extension Tube 7 For Om-1 Om-2 Om3 Om-4 Ti Om10 Om20 Om30 Om40 Questions & Answers
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
WHEN I TURN MY OLYMPUS ON IT GOES RIGHT TO "ZOOM ERROR" THEN SHUT OFF. ANY SUGGESTIONS?
When your Olympus camera goes straight to "Zoom Error" and then turns off, it is likely that there is an issue with the camera's lens mechanism. Here are a few things you can try to troubleshoot the problem:
- Turn off the camera and remove the battery and memory card. Then, wait for a few minutes before re-inserting them and turning the camera back on.
- Gently move the lens back and forth with your fingers to see if it can be moved and if it is stuck.
- Use a can of compressed air to blow dust and debris out of the lens mechanism.
- Check the lens for any physical damage such as cracks or dents.
- Try using the camera without the zoom function to see if it still turns off.
- If none of the above steps resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus camera is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
My olympus sz 14 camera shows Zoom error on the screen when I turn it on and then turns off immediately. I bought a new battery a d charged the camera but it continues to shut off.
The "Zoom Error" message that appears on your Olympus SZ-14 camera's screen when you turn it on, followed by the camera turning off immediately, could be caused by a problem with the camera's lens.
- Try gently tapping the camera on a flat surface to try and realign the lens.
- Check the lens for any dirt or debris that may be blocking the movement of the lens. Clean the lens with a soft, dry cloth.
- Check the lens for any physical damage like dents or cracks.
- Contact Olympus customer support: If you have tried all the above steps and the camera is still not working, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus SZ-14 is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
How to transfer photos taken by an Olympus Camedia C-1000 L to a computer?
To transfer photos taken by an Olympus Camedia C-1000L camera to a computer, you can use the following method:
- Connect the camera to the computer using a USB cable.
- Turn on the camera and set it to the "PC" or "Computer" mode.
- On your computer, a new drive or a pop-up window should appear, indicating that the camera has been recognized.
- Open the drive or window and navigate to the folder where your photos are stored.
- Select the photos you want to transfer and copy them to your computer by using drag and drop or "Copy" and "Paste" functions.
Alternatively, you can use the Olympus Camedia Master software that came with the camera to transfer photos. Once connected and the software is open, you will be able to see the camera's content, then you can select and transfer the photos to your computer.
It's important to keep in mind that the Olympus Camedia C-1000L is an older model camera, which may not be compatible with the latest version of computer operating systems, so it's recommended to check the software and the operating system compatibility before transferring the photos.
Olympus vn6200pc won't power on. I can plug into pc and play files and screen comes on but if not plugged into computer it wont come on. Tried disassembling but no obvious cause seen...
If your Olympus VN-6200PC digital voice recorder is not turning on, even when it's not plugged into a computer, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the batteries: Make sure that the batteries are inserted correctly and that they have enough power. If the batteries are low or dead, the device may not function properly. Try replacing the batteries with fresh ones.
- Check the power switch: Make sure that the power switch is in the correct position and that it's not stuck.
- Check the firmware: Make sure that the device's firmware is up to date.
- Try a factory reset: Some devices have a factory reset option that can be accessed through the menu or by holding down certain buttons. This will erase all data on the device, but it may fix some software issues.
- Check the charging port: Make sure that the charging port on the device is clean and free of debris.
- Contact Olympus customer support: If you have tried all the above steps and the device is still not turning on, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus VN-6200PC is an older model device, which makes it harder to find replacement parts and professional repair services.
My Olympus vn5200pc is "LOCK" mode and I can't get it unlocked
If your Olympus VN-5200PC digital voice recorder is in "LOCK" mode and you are unable to unlock it, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the manual: Consult the manual of your device to ensure that you are using the correct procedure to unlock the device.
- Check the lock switch: Make sure that the lock switch on the side of the device is not engaged.
- Change the batteries: If the batteries are low or dead, the device may not function properly. Try replacing the batteries with fresh ones.
- Contact Olympus customer support: If you have tried all the above steps and the device is still locked, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus VN-5200PC is an older model device, which makes it harder to find replacement parts and professional repair services.
How to reset time and date on olympus ws852 en
To reset the time and date on your Olympus WS-852 digital voice recorder, you can follow these steps:
- Turn on the device by pressing the power button.
- Press the "Menu" button to access the main menu.
- Use the arrow keys to navigate to the "Settings" option and press the "OK" button.
- Use the arrow keys to navigate to the "Time and Date" option and press the "OK" button.
- Use the arrow keys to navigate to the "Time and Date" option and press the "OK" button again.
- Use the arrow keys to set the correct time and date, and press the "OK" button to save the changes.
- Press the "Menu" button to exit the settings menu.
It's important to check the manual of your device to ensure the above steps are accurate, as the process to reset the time and date may vary depending on the firmware version or the model of the device.
If you still have trouble resetting the time and date, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
My olympus E50 won't save to the XD card . . .
If your Olympus E50 camera is not saving photos to the XD card, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the XD card: Make sure that the XD card is properly inserted into the camera and that there is enough space available on the card for the photos you are trying to save. It's also important to check that the XD card is not locked, damaged, or corrupted.
- Check the camera's settings: Make sure that the camera is set to save photos to the XD card and not to the camera's internal memory.
- Format the XD card: Formatting the XD card will erase all data on it, but it can also fix some file system errors. Make sure to back up any important files before formatting.
- Check the camera's firmware: Make sure that the camera's firmware is up to date.
- Check the camera's manual: Some cameras may have different settings or limitations that affect the use of the XD card.
It's important to keep in mind that the Olympus E50 is an older model camera, which makes it harder to find replacement parts and professional repair services.
ICANNOT OPEN SETTINGS WITH OLYMPUS VG140
If you are unable to open the settings menu on your Olympus VG140 camera, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the camera's battery: Make sure that the camera's battery is fully charged and properly inserted into the camera.
- Check the camera's manual: Some cameras may have different settings or limitations that affect the use of the settings menu.
- Check the camera's buttons: Make sure that the buttons on the camera are working properly and not stuck or malfunctioning.
- Reset the camera: Some cameras have a reset button or option that can be used to restore the camera's factory settings. This can be found in the camera's manual.
It's important to keep in mind that the Olympus VG140 is an older model camera, which makes it harder to find replacement parts and professional repair services.
Olympus 770sw camera. no image on lcd when taking photo
The issue you are experiencing with your Olympus 770SW camera, where the LCD screen is not showing an image when attempting to take a photo, could be related to a problem with the camera's display or image processing.
- Check the camera's settings: Make sure that the camera's display settings are set to show the live view when taking a photo.
- Check the LCD screen: Make sure the LCD screen is clean and free of any scratches or cracks.
- Check for physical damage: If the camera is not under warranty and you have the technical knowledge, it is possible to check the internal processing and the LCD screen for any physical damage.
If the above steps do not resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue, or tell you if a repair is needed.
It's important to note that the Olympus 770SW is an older model camera, which makes it harder to find replacement parts and professional repair services.
