20 Most Recent Leica Cm1850 Cryostat Questions & Answers
That sounds bad, but this section of Fix-ya is for Leica cameras. I don't know that we can be much help with their medical equipment. Good luck though.
Leica Cm1850... | Answered on Sep 17, 2019
Try to check the relays. There is what we call a protective thermostat and thermistor for the compressor. Maybe this is also busted. A starting thermistor usually gives way in todays compressors. You can see this in the connector of the compressor.
Leica Cm1850... | Answered on Jul 07, 2014
Richard:
Double-check the electrical source (plug) you have it plugged into with another device.
Just because the bulb "looks good" does NOT mean it IS good, also. If the electrical source ("the plug") is "hot", then the likely culprit is the bulb. Next would be the electrical switch - "fiddle" with it a bit.
(work it like a toilet that is problematic: jiggle the handle. wiggle things a bit. yell at it. whack it a few times)
If that doesn't work, check your warranty to see if a repair is covered.
(don't "whack it" so hard the warranty is void!)
Leica Science &... | Answered on Aug 26, 2014
Depends on the microscope. Generally, with most simple microscopes that are used often, calibration (aligning of the prisms, objectives and eyepieces) shouldn't be required more than once every 5 years or so.
Leica Science &... | Answered on Apr 22, 2014
This issue could potentially be solved by a flatfield software correction of the camera that you are using. I would recommend visiting leica-microsystems.com and filling out a Contact Me request. Your local Leica specialist will then be in touch to help.
Leica Science &... | Answered on Jan 04, 2011
Tech specs and exploded diagram http://www.clemex.com/pdf/brochures/Leica_MZ_16_Tech_en.pdf
Uusers manual http://biotech.wku.edu/online_manual/Leica%20MZ16%20Fluorescence%20Stereomicroscope.pdf
Enjoy
Leica Science &... | Answered on Oct 12, 2009
well , use test lamp to find lost power.
any desk lamp , turn it on then plug it in to all AC power jacks that connect to this AutoClave. (I assumed it is plug power and not hardwired to 240vac service)
are you in uSA< posting to USA forums?
why not just call and electrician and end this. not get shocked and all that.
no power at all to your lab , the building or just one THING, .
Science &... | Answered on Feb 29, 2020
a bunsen burner produces a small flame, it is used in laboratories for heating, sterilizing or combustion
Science &... | Answered on Dec 29, 2019
That is an autoclave and peoples life and health depend on it. Please contact the manufacturer at +39 0445 329811
Science &... | Answered on Sep 27, 2019
1. Always clean the slide. 2.Make sure that the fine and the coarse adjustment knobs do not scratch the slide by handling them gently.
Science &... | Answered on Sep 05, 2019
Turn it on and bring up the temperature. The pressure inside will increase as the temperature increases.
Science &... | Answered on Aug 19, 2019
Leica Cm1850 Cryostat Logo
3 questions posted
Top Leica Science & Laboratory Experts
Tom Chichester
ray gallant
Are you a Leica Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Leica Science & Laboratory
Most Popular Question
water leaking from leica cm1850 cryostat
  • Science & Laboratory
