20 Most Recent
Baby Trend Trendsport Lite 1520 Stroller Questions & Answers
Replacement tray
To order a replacement tray, call this number, 1-800-328-7363. You'll need to give your stroller model number (located on a white sticker behind the rear left leg) and the manufacturing date (in your manual). Don't worry if you can't find the manufacturer's date. I didn't have mine and that didn't present a problem.
I bought a Cosco Juvenille
it would seem to me that the overall frame of your buggy is bent, sounds like it drives as nice as a shopping cart that has been in an accident..
get out your mesuring tape and see where this charriot is wonky, to straighten it you could build yourself a jig and reast the frame in it and GENTLY apply presssure to attempt to make it sit straight, I would remove your front wheels and make sure they are not damaged see if the shaft that inserts into the bottom of the frame is straight and lube the hell out of it when you put it together
Thanks and good luck Shawn
How do I find assembly
Did you ever find the instructions because I just bought a used one and can't find instructions anywhere.
