20 Most Recent
Niles HD6 Main / Stereo Speaker Questions & Answers
Hi, I bought a house
First remove the wire mesh grill with a curved pin or lever it out with a sharp kitchen knife. Then you will notice four black screws very close the groove into which the grill fits.Using a correct size + screwdriver unscrew all the four screw anticlockwise till you feel the whole speaker panel shake loose. Make sure somebody is holding the outer frame while you are doing it or it might suddenly fall. The are red and black spring clip connectors for the speaker wires. Disconnect them foe removing the speakers completely.
I have a Niles Audio
the sps one is a passive device, the protection circuit is and attempt to protect your amp from very low impedance when you have mulitple speakers attached. The Protection circuit switches in a 2.5 ohm resisitor in series.If you where to connect 4 sets of 4 ohm speakers to this unit and not push in the protection switch you amp would hate you and hopefull just trip the over protection in the amp. When you push in the protection switch you add 2.5 ohms to the circuit. So with four 4 ohm speakers your load would be 3.5 ohms. The device is rated for 100 watts of music power.
The only thing inside the unit is switches and the two resistors mention above. So not much to go wrong with the unit.
If you have shorts, and not open wires it is more than likely related to the user wiring on the back of the. First make sure that all of the wires are trim to size to fit in the small terminals and you do not have any flying leads when they are inserted. Also make sure that each speaker wire polaraity is correct.
If it still does not work then you will have either a open resistor, that is apparent when it does not work and the button is pushed in. or a bad switch, Or you have way overload the unit and burn off a track on the pcb.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
