20 Most Recent Maytag 24 in. MDBH940AWS Built-in Dishwasher Questions & Answers
2answers
Dirty dishes on Maytag 24 inch dishwasher, model
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
10/3/2012 7:16:11 PM • Maytag 24 in.... • Answered on Oct 03, 2012
Water is pooling in bottom of the tub at end of
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
3/29/2011 2:34:36 AM • Maytag 24 in.... • Answered on Mar 29, 2011
The door just drops open. I guess that a spring
You should be able to do it yourself if you can slide it out from the cabinet. Post your model number HERE and you can see your parts you can order and diagrams to help. Part 11 is your spring. You need to make sure that's all you need so look at yours.
1/22/2011 8:56:11 PM • Maytag 24 in.... • Answered on Jan 22, 2011
WASHER DOES NOT TURN ON NO DISPLAY OR CONTROLES
Your control panel/keypad has shorted out on your dishwasher. You need part#99003227 Please look at item#1 for a picture of what needs to be changed http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0609011-00001.png
  1. Unscrew all the inner door screws left,Right, and top of the door.
  2. Unplug unit
  3. Separate the inner and outer door
  4. Unscrew the control/board cover and 2x screws for the control/board let hang to the side
  5. Pull out ribbon cable connecting control panel
  6. Unscrew control panel and attach new one in place
Reinstall all component and retest. This should be a good fix.
Please rate me a for if i answered your question. Have a good day!
12/13/2010 7:04:15 AM • Maytag 24 in.... • Answered on Dec 13, 2010
Rattling noise under dishwasher
Sounds like some debris in the pump.
11/4/2010 3:49:29 AM • Maytag 24 in.... • Answered on Nov 04, 2010
After starting the cycle, the
You may have a faulty drain valve,the drain valve is under dishwasher there are two clips on each side check,with applance store for replacement part.
8/29/2010 5:28:42 PM • Maytag 24 in.... • Answered on Aug 29, 2010
Grit on clean dishes.
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
7/19/2010 3:28:34 AM • Maytag 24 in.... • Answered on Jul 19, 2010
Dishwasher leave debris on dishes
there is no filter except the screen in the water inlet valve to keep big pieces of grit in the water from defecting the inlet valve..
i dont know exactly why but it sounds like your unit was not installed with a recommended air gap in the drain or something similar and somehow dirty sink/drain/sewer water is making its way back into the unit and onto your dishes.
often times there is a little rubber check valve/flapper in the drain line either installed in the pump or the drain hose just after the pump to keep foreign material from entering the unit..
other than that it would just be mineral and calcium deposits if you are on well water or chunky city water..
hope this helps,
best of luck,
ttfn
10/27/2009 3:29:18 AM • Maytag 24 in.... • Answered on Oct 27, 2009
The latch is sticking. it feels as though a
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170579&diagram_id=1332458#d1332458
this link will take you directly to the part you need your looking for part number 3
it is the hadle itself
and either one tab or both on the ends that lock it into the lock assembly have broken
its an easy repair if your paitent and willing to take your time
the new one is a bit hard to pop into place
10/21/2009 6:56:55 PM • Maytag 24 in.... • Answered on Oct 21, 2009
Can't get rid of White (Soap) buildup on machine and dishes
problem is hard water. solve it by going to www.dishwasherfilter.com. you will be glad you did.
8/6/2009 2:57:17 PM • Maytag 24 in.... • Answered on Aug 06, 2009
Dishes not getting as clean as they used to
RUN A EMPTY LOAD ON HOT WITH A COFFEE CUP FULL OF VINAGER SITTING ON THE TOP RACK, THIS WILL CLEAN THE DISHWASHER, YOU MAY NEED TO DO IT 2 OR 3 TIMES
7/10/2009 9:55:32 PM • Maytag 24 in.... • Answered on Jul 10, 2009
Mdbh940aws - maytag dishwasher not woking
It might be a thermal fuse. Check this thread:
http://www.fixya.com/support/t545481-dishwasher_panel_no_power
5/30/2009 3:11:47 AM • Maytag 24 in.... • Answered on May 30, 2009
Noise at end of drain cycle.
There aren't really all that many energetically moving parts inside a dishwasher - fewer still that are active during the drain cycle. Follow the drain hose into the machine, and you should come upon the drain pump. Have a look inside that, and in the hose that runs between it and the sump it drains. My best guess is that some piece of buoyant debris is sitting in that line, and, as the water level drops, is lowered into the pump impellor. Usual warnings about disconnecting power before putting your hands inside the machine apply - and be aware that you're likely to find a bit of dirty water sitting around in the pump. A.
1/4/2009 2:10:32 PM • Maytag 24 in.... • Answered on Jan 04, 2009
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
7/3/2008 12:44:15 PM • Maytag 24 in.... • Answered on Jul 03, 2008
2answers
CRUSTY'S LEFT IN GLASSWARE
Things that have been known to exacerbate this problem are: 1. Putting too much food in the dishwasher - especially things like breakfast cereal, rice or couscous. Try scraping plates and pots thoroughly before loading them. 2. Not cleaning the strainer/filter - if not sure how to do this, check the owner's manual 3. Putting glasses in on their sides, rather than completely upside down - this creates a puddle of dirty water that can't get rinsed off and subsequently dries crusty. Sorry if the first three are insultingly obvious - but they are the most common causes of this problem. 4. Debris in the spray arms - you can usually get them off easily enough (though beware of left-hand threads on some models), then give them a flush through under the tap. 5. One or more spray arms put back on upside down (OK, confession here - I've only seen this happen once, and it was me that had done it. Took me weeks to realise). A.
4/27/2008 10:59:48 PM • Maytag 24 in.... • Answered on Apr 27, 2008
My Maytag dishwasher turns on and runs for just under 2 minutes. At this point it switches off and shows 2 minutes remaining on the cycle as it drains out.
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
8/29/2022 8:06:11 PM • Maytag... • Answered on Aug 29, 2022
2answers
Maytag dishwasher installation problem
You will need a new hose that is longer for your dishwasher and a new water pipe and a new hose installed for the dishwasher to run.
6/26/2022 7:37:12 AM • Maytag... • Answered on Jun 26, 2022
Maytag Quiet series 300 Handle and latch seem broken
google Maytag Quiet series 300 Handle and latch there are several new handles about $30-35. link to how to replace handle copy and paste https://www.youtube.com/watch?v=Tfw0F5XeWHY ..
6/14/2022 2:15:44 PM • Maytag... • Answered on Jun 14, 2022
Maytag 24 in. MDBH940AWS Built-in Dishwasher Logo
30 questions posted
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
dirty dishes maytag 24 inch dishwasher
  • Dishwashers
