20 Most Recent Intel SuperMicro SUPER Motherboard - 810 (370SEAO) Questions & Answers
2answers
Update bios
http://admin.utep.edu/Default.aspx?tabid=56
Try downloading on right side of page.
9/8/2009 9:47:41 AM • Intel SuperMicro... • Answered on Sep 08, 2009
2answers
Driver is not avalble
Try downloading Intel 810 drivers at bootom of page.
8/19/2009 7:21:08 PM • Intel SuperMicro... • Answered on Aug 19, 2009
Bios not starting
Gitu, remove tha fan, the cpu and the RAM. RE fix them in their respective places. Switch the machine on It shud work. Check the battery on the motherboard. May be it is dead. How old in your machine? Replace the button cell on the motherboard.
8/5/2009 8:56:16 AM • Intel SuperMicro... • Answered on Aug 05, 2009
25answers
BIOS not starting
my problem is this my motherboard recently started to not open the computer at all so i take the rams out and put it back in and it works after two days from shutting down dead silent this process happes almost on weekly basis now one day it just doesn't want to open and i have to leave it for a couple of days and remove the rams and put it back in then it works and two days later stops and so on u get my point ..
one more thing started to happen the dvdrom and cd rom connected to the MB stops working also and i don't no what to do should i change to msi 945 or anyone recommend another type of motherboards or is this fixable? thanks
replay to me on [email protected] much appreciated
12/26/2008 9:02:42 PM • Intel SuperMicro... • Answered on Dec 26, 2008
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
12/24/2008 10:10:21 PM • Intel SuperMicro... • Answered on Dec 24, 2008
3answers
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
12/24/2008 9:50:42 PM • Intel SuperMicro... • Answered on Dec 24, 2008
0answers
Two4two
Be the first to answer 7/28/2008 3:22:05 AM • Intel SuperMicro... • Posted on Jul 28, 2008Be the first to answer
2answers
Ram gets detected only to half of the value specified
dear pradhan
your ram 256 but i think your ram memory shared with disply memory so . first restart your system and press DEL key untill u enter in bios setup.then go tothe advanced option and disable graphic memory then save settings and restart pc . your problem is solved.
3/18/2008 5:07:05 PM • Intel SuperMicro... • Answered on Mar 18, 2008
P4sxq won't boot
this RAM problem
12/3/2007 10:30:06 AM • Intel SuperMicro... • Answered on Dec 03, 2007
2answers
Motherboard BIOS
Unfortunately if you can't get in the bios, no beeps and assuming the memory is compatable with the motherboard, then the bios chip is damaged and there is no way forward apart from another board.
8/20/2007 7:52:40 PM • Intel SuperMicro... • Answered on Aug 20, 2007
Cmos error
ok, a checksum error can refer to a flat cr2032 cmos battery, especially if the time is wrong at every boot.
6/5/2007 10:23:33 PM • Intel SuperMicro... • Answered on Jun 05, 2007
My motherboard BIOS is not starting
look for the CLRCMOS or CLR or JBAT1 terminals. These are the cmos settings and may need to be cleared, so refer to your motherboard manual for which one you have. Although what has probably happened is that when the PSU blew it may well have shorted the cmos chip which cannot be repaired, or damaged the graphics.
4/12/2007 10:01:18 AM • Intel SuperMicro... • Answered on Apr 12, 2007
3answers
Looking for someone to help me determine a possible motherboard fault, any takers?
You wont find any schematics for motherboards online. The market is too competitive and proprietary. The most common tool in troubleshooting a motherboard now days I would say is infrared camera's. They use them to look for shorts in the components and heat in the circuit board traces.
12/3/2022 6:02:09 AM • Intel Computers... • Answered on Dec 03, 2022
Compatible motherboard and CPU with a Sony Vaio VGN-N220E laptop ?
Hi, please call geeksquad to request that they check for compatible motherboard within their inventory: 1 (800) 433-5778. This should help you reach your goal. Thank you.
10/1/2022 8:54:39 PM • Intel Computers... • Answered on Oct 01, 2022
Avira Antivirus Pro 2022 Crack
8/7/2022 7:13:28 PM • Computers &... • Answered on Aug 07, 2022
2answers
Mp4 player not working
Check your MP4 player's system requirements. Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC. Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player. Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems. Try restarting your PC if it is capable of working with your MP4 player. Restarting your PC resets non-functioning USB ports, which may be your problem. Make sure your USB cable is connected properly. If your player requires you to install drivers, make sure you install them. Try connecting your player to another PC to see if the new PC recognizes it. If it does, chances are your computer does not support the hardware necessary to run your player. Reset your MP4 player if your PC is still unable to recognize it. Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation. Contact your player's manufacturer if you are still unable to get it to work with your PC. http://applestore.altervista.org/mp3mp4.pdf
6/9/2022 2:57:40 AM • Intel Computers... • Answered on Jun 09, 2022
Is intel i3 processor sufficient for this site,slow collecting points
WHAT SITE? WHAT POINTS? IS THERE A PROBLEM STATE IT IN DETAIL. personally who needs points, ? can't buy beer with points, so are worthless.
1/20/2022 6:54:32 PM • Intel Computers... • Answered on Jan 20, 2022
Can my P5S-MX SE motherboard go with Intel E5400 pentium dual core 2.7 ghz?
wrong that mobo is not blue and is not made by intel.com at all it is ASUS..com says so on the mobo and at their web sets all mobo sold by them from 1995 to 2022, have QVL LIST ON CPU, ALL DO THERE. SO FIND IT OR ASK THEM. TOOK ME 3 SECONDS TO FIND THIS GOOGLE https://www.asus.com/us/SupportOnly/P5S-MX%20SE/HelpDesk_CPU/ QVL = QUALIFIED VENDOR LISTS, RAM OR CPU FROM 1995 TO NOW, AND ASUS.IS THE BEST DYI MOBO MAKER BAR NONE, AND GIGABYTES TOO. 2ND FIDDLE.
1/20/2022 6:29:39 PM • Intel Computers... • Answered on Jan 20, 2022
How to connect OLD hard disk 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439 to intel core2 duo? MY SECRET PC MODEL NOT TOLD.
CORE2 NOT CORE CORE 2 IS 2006 TECH.(first)A 13 year old PATA drive, reviews 2005 yah a relic. No PC model told ,desktop or laptop? 2006?intel only mobo ?. not told|I will not cover, mobo with via or sis or Nforce chips with IDE support. just intels. and not Marvell chips on the mobo, or the like. 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439it just plugs into a IDE (PATA) 40pin port. it is NOT A SATA drive. ( i BET IT IS BAD)there are only 3 ways to use any PATA (ata ide)DRIVEA MOBO WITH THE 40 PIN PATA PORT.THERE.OR AND PCI ADAPTER PATA THERE. (WITH BOOT ROM IF NEEDED)OR A SATA TO PATA DIRECT ADAPTERTHAT IS ALL There is. (got the last pata drive on earth not dead, is that it?the last real intel mobo with PATA ports is ICH7and is CORE2. P31 +ICH7 chip set.?(yes some PCs had Marvell chips on board to add IDEto ICH8 PCs that intel ended, IDE forever Ich7 south bridge has old IDE pataICH8 mobile has IDE BUT NOT ON desktops and others.ICH9 may 2007 ends IDE in the intels chips forever..NO PC MODEL TOLD OR IF DESKTOP WHAT MOBO IS THERE.IF EVEN IF A SERVER, NOT TOLD.IT JUST PLUGS-IN, SET JUMPER TO SLAVE IS 2ND DRIVE.NOT TOLD IF IS BOOT DRIVE. ETHER.
1/20/2022 6:23:01 PM • Intel Computers... • Answered on Jan 20, 2022
Computers & Internet Logo
13 questions posted
Top Intel Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
bios not starting
  • Computers & Internet
