20 Most Recent Jabra BT620 BLUETOOTH STEREO HANDS-FREE HEADSET Headset Questions & Answers
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
Jabra BT620... | Answered on Aug 17, 2019
Have you gave driver booster a try worked for me
Jabra BT620... | Answered on Sep 22, 2017
wachsen ein Gehirn
Jabra BT620... | Answered on Jun 01, 2011
Try This download n install
Hope it resolve your issue
Thanks
Harry
Jabra BT620... | Answered on Apr 17, 2011
if it doesnt have a cord on the end you cant hook it into the laptop but if you have a cord on the end look on both sides of yuour laptop and if you see a hole but it in there if it fits
Jabra BT620... | Answered on Mar 01, 2011
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Jabra BT620... | Answered on Jun 11, 2009
I had this same problem with my sony vaio (vista). But at first for me, after BT enabled the device, I couldnt find it in the device manager. I cycled on and off the headset a couple of times and once my vaio began to automatically connect the device, I was able to locate it in the device manager. Next, I went through the contol panel, hardware/sound, "manage audio devices". Here the bluetooth headset was located. After sucessfully testing the headset, I set it to default. Now whenever I fire up the headset, I have total mobile sound...awesome
Jabra BT620... | Answered on Jan 15, 2009
someone just gave me a hotfix from MS. works great!
[email protected]
Jabra BT620... | Answered on Jan 03, 2009
Geez mate, you are so smart.........
Jabra BT620... | Answered on Aug 14, 2008
Read the instructions and if you are certain the headphones aren't operating out of the box as per the instructions, return them under warranty.
Jabra Radio... | Answered on Feb 01, 2020
If your phone is connected via Bluetooth to the Jabra, I cant see why not. It would be a case of try and see otherwise contact the suppliers and ask them.
Jabra Radio... | Answered on Jun 16, 2019
Jabra BT620 BLUETOOTH STEREO HANDS-FREE HEADSET Headset Logo
26 questions posted
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
got jabra
  • Radio Communications
