20 Most Recent
Jabra BT500 Wireless Headset Questions & Answers
Hello. I can't seem to
1. Turn headset
off. Press and hold until solid light comes on.
2. Activate
Bluetooth on your phone.
3. Search for
Bluetooth devices and select Jabra BT500.
4. Press ‘OK’ on the phone ,If the
phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Forwarding txt msgs to email in bulk
Hi
Thanks for using FixYa. Yes it is correct it can be done by using bluetooth or data cable with your computer. You have to connect your phone with your computer/laptop by using Bluetooth or data cable. After this is done you'll need to sync your contacts with the computer using Microsoft ActiveSync(Windows Xp) or Windows Mobile Device Center(Windows Vista). After the contacts are synced you'll need a bulk SMS software. There are many sms softwares available, you can download and install one from these links--
Bulk SMS software Link 1
Bulk SMS software Link 2
Bulk SMS software Link 3
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Unit won't charge and I get no lights
I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site.
http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx
Hope this helps.
IT'S NOT PAIRING
Sounds dumb, but have you tried turning your phone off and back on? My Motorola was doing the same thing, exchanged it 2 times before the service tech was in the store & told me what to do.
Jabra BT500
the pin number is 0000, press and hold button until the light stays on to pair with your phone.
Beeping sound
if you use phone without headset do you hear beeping?
Paring problem
Any error msg on fone???
Please explain in more detail the issue.
