20 Most Recent Lexmark OfficeCenter X3350 All-in-One Printer Questions & Answers
The x3350 printer has no power
Ordered a new power cord.
7/26/2013 11:14:19 AM • Lexmark... • Answered on Jul 26, 2013
Need the all in one center download for windows 7 64-bit
Try using the Vista 64 bit drivers. Click on the link below for the direct link for the Lexmark X3350 Windows Vista 64bit driver.Driver link:http://downloads.lexmark.com/downloads/cpd/cjs3300EN.exe
12/14/2012 3:45:46 PM • Lexmark... • Answered on Dec 14, 2012
Paper drags at the end of printing and smears the end of picture
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 3300 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
1/18/2012 12:25:56 AM • Lexmark... • Answered on Jan 18, 2012
I have put new ink
Print quality issues could be due to dirty or clogged nozzles. Please follow the steps below to clean the print cartridge nozzles:
Clean Cartridge Nozzles (Solution Center):
1. Go to Start, Programs(Windows XP: All Programs), Lexmark 3300 Series, Lexmark Solution Center.
2. Click the Maintenance tab.
3. Click Clean to fix horizontal streaks.
4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
5. Print a document again to verify that the print quality has improved.
6. If you are still not satisfied with the print quality, follow the instructions in this article How to Clean the Print Cartridge Nozzles and Contacts Manually.
10/3/2011 7:47:07 AM • Lexmark... • Answered on Oct 03, 2011
I have an lexmark all
Though Lexmark does not recommend using refilled ink cartridges, you may try to refer to this article in the Lexmark website on Unsupported Cartridge Error on a Lexmark X3330/X3350 All-In-One to determine and resolve the problem. If error continues, try to insert a different known working cartridge. Thanks.
3/9/2011 10:47:41 AM • Lexmark... • Answered on Mar 09, 2011
I have Windows 7 and
lace d67,
Lexmark sometimes has bad software. I would recommend going to this site http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X3350&page=product&frompage=null#1 and downloading the most up to date driver for your printer. I have a tip at http://www.fixya.com/support/r6370947-install_printer_without_install_cd which will help walk you through the process.
Thanks for using FixYa and for the great rating and testimonial.
hardrocko
11/20/2010 1:57:34 AM • Lexmark... • Answered on Nov 20, 2010
How do I add the printer without the disk to my
11/15/2010 6:41:25 PM • Lexmark... • Answered on Nov 15, 2010
Lap top will not accept download..as new
I've attached the link below choose the correct operting system that you have and download the driver.
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US+&question=X3350&productCode=LEXMARK_X3350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X3350&searchid=1287175045874#2
10/15/2010 8:39:26 PM • Lexmark... • Answered on Oct 15, 2010
I need a driver for
You may copy and paste the web address below to access the Lexmark X3350 printer driver:
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US&question=X3350&productCode=LEXMARK_X3350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X3350&searchid=1284528099167#2
Please use the following steps to download the Lexmark X3350 driver to your desktop:
1. Click on "Downloads."
2. On the "Driver for Microsoft Windows 2000, XP and Server 2003" screen, choose "Save."
Note: Please select the operating system installed in your computer.
3. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
4. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
5. Once the files have completed downloading, double click on the icon with your file name.
6. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
7. A screen will then display the number of files unzipped successfully, click "OK."
8. Please follow the on screen instructions to complete installation of your Lexmark printer.
Jeethu
9/15/2010 6:12:14 AM • Lexmark... • Answered on Sep 15, 2010
How to clean rollers on a lexmark 3350
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached.
Next, try this printer self-test by following the steps given below:
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
Tech Suppot
Jeeth
9/15/2010 4:32:11 AM • Lexmark... • Answered on Sep 15, 2010
Paper not feeding evenly. It
Check for object on the paper path.
Clean/Replace the paper pickup roller.
8/11/2010 7:43:17 PM • Lexmark... • Answered on Aug 11, 2010
I hooked my printer up to a new computer & i
Uninstall the driver, unplug the printer, and start again being very careful to get it all in the right order. First, install driver, then connect printer and turn on. Hopefully it works the 2nd time! :)
7/20/2010 3:45:32 PM • Lexmark... • Answered on Jul 20, 2010
I need drivers for my lexmark X3350. Where can I
Download the required driver based on your operating system from below location:-
http://support.lexmark.com/index?page=recommendedDownloads&locale=en&productCode=LEXMARK_X3350&segment=DOWNLOAD&actp=RECOMMEND&userlocale=EN_US&id=DR20270#1
7/4/2010 9:34:11 AM • Lexmark... • Answered on Jul 04, 2010
X5470 error #1203
This may work
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
4/25/2010 6:09:47 PM • Lexmark... • Answered on Apr 25, 2010
The Lexmark X3350 printer paper jam
Try this:
turn off you printer
unplug the power cable
lift you printer up
while lifting, put it in an upside down position
then shake your printer from left to right for about a min. or 2
then put the printer back to its normal position
turn it on
then check if the issue persist.
2/26/2010 4:16:26 PM • Lexmark... • Answered on Feb 26, 2010
Had computer worked on & now it does not have
You can download the drivers right from Lexmark. Click here for Windows XP drivers or here for Vista drivers. The site has instructions on how to install the drivers if you need them.
Hope this gets you printing soon. Thanks for using Fixya!
2/11/2010 10:21:02 PM • Lexmark... • Answered on Feb 11, 2010
Switched on paper jam took paper out , same result
restart both printer and pc
it will ok
11/11/2009 7:51:17 PM • Lexmark... • Answered on Nov 11, 2009
Lexmark OfficeCenter X3350 All-in-One Printer Logo
62 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
need all in one center download windows
  • Office Equipment & Supplies
