20 Most Recent Lexmark X7350 All-In-One Printer Questions & Answers
2answers
How do i scan my printer to my computor
You need to install the printer with its software to your computer
2/2/2023 8:24:09 PM • Lexmark X7350... • Answered on Feb 02, 2023
2answers
How do I get my Windows 7 laptop to add printer
Lexmark do not provide a driver for this printer for windows 7. The latest version is for XP only. http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X7350#1 You could use the XP as a printer server, i.e. it would interface to the printer, but accept documents from a Windows 7 laptop. This web page shows how to set up the XP printer as a network printer on the network as windows 7 resource. How can share printer on Windows 7 x64 with Windows XP x86
2/2/2023 8:24:05 PM • Lexmark X7350... • Answered on Feb 02, 2023
2answers
My Lexmark printer won't recognize the new black cartridge.
eror code 3.369.03.2.25
1/31/2023 9:06:00 AM • Lexmark X7350... • Answered on Jan 31, 2023
3answers
Lexmark 7300 series I need
Hi daybreaker69 lexmark 7300 series drivers (win7/win8) can be found at driverupdate us . (32/64 bit) It will take 2 mins from you to install... after updating, go to word and try to print something I hope I have helped you... enjoy
11/7/2014 8:19:05 PM • Lexmark X7350... • Answered on Nov 07, 2014
I need a cord for my lexmark fax/printer/and copyier machine
Search for Clover leal C5 power cable / lead / cord Plenty around especially on ebay. Serch for 32FB adapter if you want the actual power unit.
10/1/2014 9:45:35 AM • Lexmark X7350... • Answered on Oct 01, 2014
Does the vista driver works with windows 7 32bit?
Probably not, If you recently upgraded from one version of Windows to another, it's possible that the current printer driver is for the previous version of Windows. If you've had recent power outages, viruses, or other computer problems, it's possible that the drivers have become damaged. Downloading and installing the latest driver for your printer can resolve these types of problems.Go to Microsoft.com at the top select downloads then select drivers then on the left printing and drivers third one down says download and instal drivers click on it then click on Automatically get the latest drivers and software Windows Update checks for updated drivers and software for your devices and installs them automatically. Keeping Windows Update on is a good way to make sure your devices continues to work properly and you get the best experience with them.Hope this helps!
5/2/2014 12:08:33 PM • Lexmark X7350... • Answered on May 02, 2014
Wont turn on
did you check the usb cable try another cable if not check the power cord if it dose not turn on then you need a new one
10/29/2013 5:08:24 AM • Lexmark X7350... • Answered on Oct 29, 2013
Cannot get my lexmarkx7350 to work on my computer
In this case you need to follow 2 steps: 1: In this case what i would request u to do is: 1. Let the Printer be Connected to the Computer...... 2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista....... 3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop.......... 4. Now let that Window still be Open now click on that start Menu Click on Run If XP........ Type in "Spool" and Click Ok........... 5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder........... 6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler.... Once this is done if you refresh the Devices and Printers Page you would find the exclamation mark gone from the Printer icon now follow the below steps to install the Printer again: Now go ahead and download the software from the following Link: http://support.lexmark.com/index?page=productSelection&channel=supportAndDownloads&locale=EN&userlocale=EN_US Just go to this Link and select ur Product & the operating System. Download the drivers from here and install the Printer..... Good Luck!!!!
5/13/2013 6:13:22 PM • Lexmark X7350... • Answered on May 13, 2013
3answers
I lost the Lexmark X5650 Printer, Scanner, Copier
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
4/9/2013 3:35:48 PM • Lexmark X7350... • Answered on Apr 09, 2013
I dont know how to connect the printer
printer ko pc se connect kare pc me drive software insert kare use active kare
9/1/2012 6:06:23 AM • Lexmark X7350... • Answered on Sep 01, 2012
How can i conect a printer
Your printer came with a USB to mini USB cord. The mini end plugs into the back of the printer and the USB into any USB port on the back of your computer tower. The computer will recognize new hardware and walk you through install. murf427
8/31/2012 1:51:22 AM • Lexmark X7350... • Answered on Aug 31, 2012
X7350 lexmark to windows 7
you will have to remove the printer software and then reinstall it again some of the driver flies has gone when you clean the system from virus
4/18/2012 11:07:36 AM • Lexmark X7350... • Answered on Apr 18, 2012
Cant install printer without disc
go on to lexmark uk site, drivers and download from there
12/1/2011 5:02:20 PM • Lexmark X7350... • Answered on Dec 01, 2011
We want to be able to use the lexmark X7350 for
you will need to either share the printer from one laptop and configure the other laptop to use the printer on the other laptop.
you will need to make sure your in the same workgroup for both laptops in order to share files/printers over the network.
the other option is to buy a print server that will support your lexmark printer and connect to the network via either wifi or cat5.
9/20/2011 11:17:14 PM • Lexmark X7350... • Answered on Sep 20, 2011
I have a lexmark 2600
This photocopier can only copy 1 page at a time. This is due to only being able to place one sheet on the viewing surface per scan.
To make a scan follow these instructions:
  1. Open lid and put the document or photo face down
  2. Close the lid to press the document flat and avoid dark edges
  3. Have the printer connected to the computer and both turned on
  4. Press the scan icon on the printer
  5. Follow onscreen instructions
  6. Repeat for each document needing to be scanned
9/14/2011 4:42:38 AM • Lexmark X7350... • Answered on Sep 14, 2011
Lexmark X7350 All-In-One Printer Logo
128 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark 7300 series need
  • Office Equipment & Supplies
