20 Most Recent
Maytag MER5770 Electric Kitchen Range Questions & Answers
Not unless you have special gear. the control module that regulates heat output in the bake mode is not working properly and may need replacement.
Maytag MER5770...
Answered
on May 02, 2017
A RAZOR BLADE IS THE BEST.BUT IF ITS BURNT ON ITS VERY HARD TO CLEAN.ANY TYPE OF SUGAR IS THE WORSE FOR SMOOTH TOPS.IF YOU THINK ITS A DEFECT YOU MAY HAVE A 10 YEAR WNTY.CHECK YOUR BOOK If you need further help, I’m available over the phone at
https://www.6ya.com/expert/dude_653d05454b389bba
Maytag MER5770...
Answered
on Jan 04, 2015
The sensor is not repairable. You need to check to see if it's bad and replace it if it is or look elsewhere for the problem. Should measure around 1,100 ohms at room temperature
Maytag MER5770...
Answered
on May 28, 2014
Roger. Thank you for the correct model number ! That helped! Your model has a high limit safety thermostat located either in the back of the range or under the cooktop. The service manual does not specify where, but on previous service calls, we find them usually in the back of the range, behind the metal back panel. This has gone bad. Usually after a self clean. 71001844 THERMOSTAT, HI-LIMIT - $43 and simple to replace.
High Limit Thermostat 71001844
Maytag MER5770...
Answered
on Apr 11, 2014
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Maytag MER5770...
Answered
on Dec 10, 2013
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
Maytag MER5770...
Answered
on Jul 31, 2012
