20 Most Recent Logitech Mobile Freedom Wireless Headset Questions & Answers
3answers
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
8/11/2021 5:53:40 AM • Logitech Mobile... • Answered on Aug 11, 2021
2answers
Quick Start Guide
I have one that i left discharged for a few months... battery will not take a charge... unless you know how to replace the battery, having a charger may not help much... good luck..
12/9/2016 8:42:50 AM • Logitech Mobile... • Answered on Dec 09, 2016
Hi i get clicking noise when other person receives
I dont owe one.
2/1/2011 6:41:00 PM • Logitech Mobile... • Answered on Feb 01, 2011
I need a chager for this item logitech F-02288A
use "mini 4p" usb cable
1/30/2010 5:34:58 PM • Logitech Mobile... • Answered on Jan 30, 2010
Lost my charger
Use "mini 4p" usb cable.
1/30/2010 5:31:18 PM • Logitech Mobile... • Answered on Jan 30, 2010
5answers
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
5/23/2009 12:45:33 PM • Logitech Mobile... • Answered on May 23, 2009
Not charging
We need a charger for this headsets since I am looking for a charger for mine
can you post chargers on the accessories model F-0399A.
thanks
George
4/22/2009 8:22:55 AM • Logitech Mobile... • Answered on Apr 22, 2009
Logitech hands free mobile unit
sorry guys i don't think it's replaceable. i'm fiddling with mine now but no luck in getting it out... far less getting one back in...
by the way, did any of you get problems charging it in the beginning?
4/18/2009 10:39:39 AM • Logitech Mobile... • Answered on Apr 18, 2009
No response
find a nokia 6300 manual, i currently have this phone and it is quite easy to use, otherwise try referring to the manual for your headset. if you could also post the part about connecting your headset via bluetooth it would be helpful because i dont know how to pair the headset you are reffering to. (the problem for me the headset not the phone).
4/14/2008 7:11:08 PM • Logitech Mobile... • Answered on Apr 14, 2008
Hi, I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected. Hope this helps.
1/14/2018 11:43:45 PM • Logitech Radio... • Answered on Jan 14, 2018
Logitech PC Headset 880
is the minijack plug compatable with your mike
12/28/2017 1:11:55 PM • Logitech Radio... • Answered on Dec 28, 2017
Logitech Mobile Freedom Wireless Headset Logo
Popular Tags
20 questions posted
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Radio Communications
Most Popular Question
default passcode logitech f 0228a mobile
  • Radio Communications
