20 Most Recent Logitech Inc MM50 Portable Speakers iPod Computer Speakers Questions & Answers
Helpme! Battery Death!
You cannot repair or bring back to life a dead battery. Get some money and buy a new one. Can you bring back to life a dead human?
3/22/2017 4:25:08 PM • Logitech Inc... • Answered on Mar 22, 2017
4answers
Will not charge
If this Problem has come because you not use a speaker for a long time.I Know How to Repair. In This Morning. I had a Problem Like you but I Can Repair it. Try it you Self.I use a Plug and Play a lot of time. lot of charged. and a lot of on-off switch mm50. I do this for a 12 hour. in my school holiday. Battery is become life! . I Can Portable with It Again. but now is mid night
PS.This is true , I test with myself to Resurrection that Death Battery
2/12/2015 9:24:47 PM • Logitech Inc... • Answered on Feb 12, 2015
2answers
Speakers work when plugged into electrical outlet however will not work on battery power
hey u r using speakers..so i think power is not suff for them to run..so use dc flug boards..i mean direct curr...
y do u try for a batery??itz waste of money
11/17/2013 11:43:11 PM • Logitech Inc... • Answered on Nov 17, 2013
3answers
Battery down but ok with power on MM50.
The battery for the MM50 speaker is VERY hard to find. Logitech does not make a replacement battery for this unit but here is a link to a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod SpeakerThe battery has a plastic connector which connects to the board so soldering will not be necessary. You just open up the back and switch it out. Easy Peasy!
7/23/2013 8:43:52 PM • Logitech Inc... • Answered on Jul 23, 2013
2answers
Logitech mm50 speakers
if no light came from the speakers then something is corrupted inside them .. you have to check the power source and power cable of the speakers first ... if everything is fine then the speakers are corrupted from inside
7/23/2013 8:40:34 PM • Logitech Inc... • Answered on Jul 23, 2013
3answers
Flashing Lights and No Sound
I am 100% sure the battery is dead.
Opening my mm50 I find that the small 2"X 1/4" battery is attached to the back, very near the charging socket. The battery is connected to the circuit board through a small plug-socket arrangement - no soldering here like iPod. So, it would not be difficult to replace it by a DIY enthusiast. But it would be difficult to find this non-standard replacement battery. Better leave the job to Logitech service, they'd would certainly replace it on charge basis.
=Subhas Chatterjee=
11/28/2012 10:11:55 PM • Logitech Inc... • Answered on Nov 28, 2012
2answers
Battery
yeh surely u can shop it via ebay itself
11/28/2012 10:10:05 PM • Logitech Inc... • Answered on Nov 28, 2012
On the Logitech mm50 Portable Speakers for iPod, the + volume button plastic cover has fallen off. Can I fix it myself?
Glue will not usually work---use something not sharp like a plastic wand to activate the micro switch---as far as the buttons they are usually a one piece part that is either melted in place or screwed--may be a little hard to locate.
6/17/2012 7:20:46 PM • Logitech Inc... • Answered on Jun 17, 2012
My mm50 speakers just stopped
The power supply adapter is most likely the culprit. You can find a 12V Logitech mm50 replacement here: https://www.digidave.co.uk/jshop/product.php?xProd=4762
3/9/2011 4:30:58 PM • Logitech Inc... • Answered on Mar 09, 2011
How do you get the speakers to play through the
There should be a green headphone jack that plugs into the headphone or green speaker jack on your computer
8/16/2009 2:56:12 PM • Logitech Inc... • Answered on Aug 16, 2009
Mm50 as extension from MacBook
Your Logitech MM50 has an auxiliary input that accepts industry standard 1/8" (3.5mm) stereo cables. The Macbook's headphone out jack with the icon of a small set of headphones is the audio out. You will need a male to male cable which is available from Radio Shack for a few dollars.
7/10/2009 6:45:45 PM • Logitech Inc... • Answered on Jul 10, 2009
No volume control
i dont have a volume control
6/3/2009 11:54:57 AM • Logitech Inc... • Answered on Jun 03, 2009
I am about to purchase a low cost portable GPS for
yes look for one with an headphone out put
then also purchace a radio transmitter adapter that allows you to send the signal to car rdio and then you can adjust the car radios volume so u may hear it.
there are other device out there for the hearing impaired . how ever most have sign language on them.
another suggestion is to get one with a bigger screen. with a quick glance while driving it will show you route highlighted in color . so you will still be able to follow the route ok
4/30/2009 8:19:06 PM • Logitech Inc... • Answered on Apr 30, 2009
Logitech mm50
I think maybe the speakers blew out because of how loud people put there IPods. It is busted so buy a new one.
12/8/2008 10:06:51 PM • Logitech Inc... • Answered on Dec 08, 2008
MM50 SPEAKERS ON OFF
To get them working do switch off then back on or what???
10/24/2008 10:42:34 PM • Logitech Inc... • Answered on Oct 24, 2008
Pure-Fi Anywhere Speakers
Well I am not sure where exactly you want them to work but there are a few options that you can concider. First off the sell power inverters that allow you to plug into the cigarette lighter in your car and you are able to plug things into your car that normally only work in the house.. The main point of my answer is that they are powerd speaker that have to be plugged into an outlet to work, my best suggestion to you would be to take them speakers back and buy a set that do not require to be plugged in. If your intention is to use them on a laptop the make speakers that plug in usb and use the small current that runs through the usb cable to power the speakers, but that will cut into your laptop battery life. If you go to a computer store and I am not talking about Best Buy I mean a real computer store they will have knodgeable staff that will be able to show you the best solution to your problem.
I hope this helps.
8/6/2008 4:49:34 PM • Logitech Inc... • Answered on Aug 06, 2008
How do i order a power cord
You can get the "power cord" for your Logitech MM50 from here. (http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11200700)
Hope this be of help/ Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
1/29/2008 11:45:10 PM • Logitech Inc... • Answered on Jan 29, 2008
Logitech MM50
Yess i have both and they work fine!
haha it works with most iPods!
1/10/2008 7:59:01 PM • Logitech Inc... • Answered on Jan 10, 2008
Mm5o docking station
try to find some reminder inside the IPOD that turns it on daily and turn the reminder off
12/28/2007 11:39:30 PM • Logitech Inc... • Answered on Dec 28, 2007
28 questions posted
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
battery down but ok power mm50
  • Audio Players & Recorders
