20 Most Recent
Microsoft Comfort Curve 2000 Keyboard Questions & Answers
Microsoft Comfort Curve 2000 v.1 Key ) problem
Right, I've done a more extensive search on google for this and it turns out that you don't have to take your keyboard apart for this.
My I key wasn't working, so I found out that all you have to do is lift the keyboard up, turn it sideways and give it an almighty slap on the back.
Solved my problem!!
1/10/2023 1:51:26 PM •
Microsoft...
Answered
on Jan 10, 2023
The letters m and eye on my Mcrosoft 2000v1.0do not work often
You MAY have something under the keys. Turn the keyboard upside down and tap the edge against the palm of your hand. This should dislodge anything that has worked its way under the keys.
Good luck and please let me know how this works out for you.
~ Spoem
7/5/2021 6:32:01 AM •
Microsoft...
Answered
on Jul 05, 2021
I just bought a brand new microsoft keyboard and
Is it wireless? If so, it might need batteries, the USB receiver may need to be inserted in a USB port, there may be a button on or under the keyboard that needs to be pressed within a few seconds of one on the USB receiver.
1/31/2018 11:48:16 PM •
Microsoft...
Answered
on Jan 31, 2018
Letter between c and b wont work!
its the paste
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
9/22/2011 4:58:28 AM •
Microsoft...
Answered
on Sep 22, 2011
Microsoft Comfort Curve Keyboard 2000 'K' Key doesn't work
I had The Same Problem !!!!
Even worse !!!
At first "B" and "A" Were not working And suddenly it worked !!
after that "R" and "M" Stopped working !! and again it worked !!!
and evrey time the same story happen again until I gave The keyboard a Good hit
only then it started to work !!!!
1/21/2011 1:50:33 AM •
Microsoft...
Answered
on Jan 21, 2011
