20 Most Recent Maytag MGR5755QD CleanDesign Gas Kitchen Range Questions & Answers
Hello Steve,Sorry it took me so long to answer ya i missed the email notifying me of this i apologize!!So when you replaced the igniter was it for the broil or the bake?? And i wonder if by chance did ya accidently reverse the wires on the gas valve and inadvertently plugged the bake broil wire into where the bake igniter and vice versa i know that probably is not the case but no harm in asking.also does the bake igniter glow when set to bake...maybe ya want to recheck the wiring to the new igniter,what i believe you hear click is the relay on the control clicks so i think based on it clicking the control board is good and the problem lies in the igniter or gas valve.Please respond and let me know if you should need further assistance.Thanks for using Fixya.GENE
Maytag MGR5755QD... • Answered on Oct 31, 2011
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Maytag MGR5755QD... • Answered on Sep 09, 2011
This problem is usually associated with lighting problems. The ignitor gets weak and then you have other issues like this. This tip will help you understand the problem.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Maytag MGR5755QD... • Answered on Nov 23, 2010
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dfasfdas
Maytag MGR5755QD... • Answered on Sep 30, 2010
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Maytag MGR5755QD... • Answered on Jul 17, 2010
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Maytag MGR5755QD... • Answered on Jul 15, 2010
Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 5 seconds. The instructions are listed on Page 12 of the owner's manual.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please let me know. I hope this helps you.
Maytag MGR5755QD... • Answered on Apr 02, 2010
Hi.
It can be fixed.
The part that is most commonly causing the problem is the temperature sensor.
When the problem is the temperature probe, both baking and broiling functions are affected.
Regards.
Maytag MGR5755QD... • Answered on Mar 02, 2010
Hi
Thanks for using FixYa. From what you have described you need to replace the igniter. To replace the igniter remove the lower cover in the oven and the burner cover and you can access and replace it. It is actually quite easy, the bottom base comes out of the oven usually held in by just 2 screws. Remove the base then it will expose the bake burner and the igniter--- the igniter is held in by 2 screws remove the screws and replace the igniter.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Maytag MGR5755QD... • Answered on Jan 29, 2010
u would need an lp kit some of the ranges came with the unit check the unit pull the drawer out and check below maybe taped to frame or chcek the rear backside for some orfices, u are gonna have to replace the orfices on the top burners.. also if its gas oven the same will be required by flipping the cap to the regulator and making some adjustments inside as well..... hope this help
Hello. Contact your propane provider and they will get you the conversion kit for your maytag model. In fact, they will send a technician to your home for free to make the conversion for you.
If you want to do it yourself go to any appliance store that handles maytag and get the conversion kit. Then remove the orifices that are currently in the stove and replace them. Regards, Joe
PS please rate my answer.
Maytag MGR5755QD... • Answered on Dec 17, 2009
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Maytag MGR5755QD... • Answered on Aug 17, 2009
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Maytag MGR5755QD... • Answered on Mar 12, 2009
Only Whirlpool would know. What do you want to Decode? Made in the USA by Whirlpool under licence to Maytag with the Maytag badge on it. The serial number is a just a consecutive number, yours is the 8,560th one to be made.
Maytag Kitchen... • Answered on Feb 08, 2021
Maytag MGR5755QD CleanDesign Gas Kitchen Range Logo
Popular Tags
26 questions posted
Top Maytag Kitchen Ranges Experts
gbob59
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
error 5sb maytag gas oven reset
  • Kitchen Ranges
