20 Most Recent Mustek A3 USB Flatbed Scanner Questions & Answers
Hi anderoland
There is no support at Mustek's for Windows 7 . You can't use your device under this OS .
best regards ,
fanaudi .
Mustek A3 USB... | Answered on Oct 01, 2017
Yes the Mustek A3 2400S can run on OS X 10.8.
Go to http://www.mustek.com.tw/support/driver-manual-downloads.html . Check the serial number of your Mustek A3 2400S scanner. Then use the drop-down menus in the left column of the page to choose the scanner model and indicate the first three alphanumeric characters of the serial number. Then select Driver and ayour OS. The Mustek site has a driver for the D3K models that covers OS X 10.7-10.12. For the scanners with D18 serial numbers, there is a driver for OS X 10.6-10.8 and a second driver for OS X 10.8-10.11.
I hope this helps.
Mustek A3 USB... | Answered on Jun 01, 2017
All the drivers can be downloaded at http://www.mustek.de/a3-usb-600-pro-307/
Mustek A3 USB... | Answered on Dec 07, 2015
click here to download driver and installation instruction
Mustek A3 USB... | Answered on Jan 09, 2015
Here you have link for drivers:
Drivers
Mustek A3 USB... | Answered on Nov 30, 2013
Please find below the link for the source:
http://mustek.de/en/253
Good Luck!!!!!
Mustek A3 USB... | Answered on May 14, 2013
This happened to me, and it was a mechanical issue/design flaw, not a driver issue. When you open up the scanner, you should see a black belt inside, under the glass. For me, that black belt got caught on some of the bits protruding from the green circuit board.
To solve this, unplug your scanner. Get a long, very thin stick. It needs to be able to fit inside the small holes on the bottom of the scanner near the circuit board and wiggle around (I used the needle of one of those compasses used for drawing circles). Depending on where the belt is caught, you may be able to use the stick to gently pry it off of the circuit board where it's stuck.
This fixed the problem for me and allowed the scanner cartridge to move freely again. Unfortunately, in my case, the belt is all bent out of shape from the scanner struggling to pull against it, so it's more prone to getting caught again. So it's a temporary fix.
Mustek A3 USB... | Answered on Feb 15, 2013
I succeeded into installing and using the Mustek ScanExpress A3 USB!
I downloaded the driver for Windows Vista from the Mustek website, then did the following steps:
1. left mouse click on the web.exe downloaded file and choose Properties;
2. in Properties I checked "Execute this program always as Administrator" and "Execute in compatibility mode for Windows Vista";
3. without any scanner connected I executed web.exe, gave the authorization even if recognized certificate;
4. allowed the system to restart;
5. connected the scanner;
6. directly used it into any program.
Please let me know if these instructions was useful!
Regards and good luck.
Sandro from Italy!
Mustek A3 USB... | Answered on Feb 08, 2012
You should be able to import/scan to a graphic software (photoshop, fireworks), once you have the graphic/picture fully scan you can save it in any format you wish.
Mustek A3 USB... | Answered on Sep 22, 2011
Mustek A3 USB Flatbed Scanner Logo
110 questions posted
Top Mustek Office Equipment & Supplies Experts
Mike
Joe Negus
Joe Negus
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mustek Office Equipment & Supplies
Most Popular Question
drivers
  • Office Equipment & Supplies
