20 Most Recent
Packard Bell Storm Diamond Audio Speakers P/n 6904700200 >>free Delivery>> Questions & Answers
Drivers
You may need an updated driver or make sure you have connected them to the sound card correctly.
How do i connect speakers to PC ?
If you have WS media player its automatic once you connect the speaker jack into the audio hole...dont forget to check if your speakers require power, plug them and increase the volume to an audible level.
If after all above has been done and no sound go to: Control Panel+ sound+ sound and click the drop down so you are able to change the option to windows default...click ok and apply. Then close and re open windows o play sound.
Audio key 256mb lost
The issue quiet short, and I am not sure how to start on a solution, it would be fine if I may need more information so that I can give you a precise solution?
Thank you.
I recently bought the Studio
be sure it is powered and on when you connect it ..and also the driver was installed into computer ...after that if it doesn't detect it ...run the add new hardware wizard from the control panel ..and select the already added feature..and see if it detects it ..If it do not came with a driver ..t means it is a plug and play device and it will be seen and installed auto ..
after that you should see it in the my computer folder as a drive ..(removable ) ..
al so be sure you confirm the connection with the p con the player if it asks ..(or take a look if it has a pc connection mode on menu or like a button feature)
Recording from baby monitor
I am assuming the model you are using is similar or the same as the model I used once. That being the case, you need an external recording device and you simply use the headphone jack to connect the two. You should be able to use your computer and some simple recording software.
How to disassemble mx5020 speaker?
Greetings,
Please check the handbook of your device to see if there are diagrams highlighting the location of the screws for the speakers. Once located, you can start by using a screwdriver to remove those screws and open up the device. Otherwise, you might need to work with an electrician or possibly a pawnshop to help get the device open. Thank you.
I bought a PSWi-8M wireless
Unfortunately you need the transmitter. i would contact Polk and see if they sell this part separately or start scouring the internet. someone might have blown their sub but the transmitter would still work.
Motorola DCP-501 All-In-One Home Theater Receiver will not come on at all?
Check the power source and if you can get behind the switch, check for continuity. Make sure that the device is properly connected to a power source and that the outlet is functioning. You can test the outlet by plugging in another device.
Check the power cable and make sure that the power cable is properly connected to the unit and the power source. Also, check for any damage or fraying on the cable.
Check the power switch to ensure that the power switch is turned on. It is possible that it might have been turned off accidentally.
Try resetting the device by disconnecting it from the power source, waiting for a few minutes, and then plugging it back in.
If all those fail, you will need to take to an audio engineer.
