20 Most Recent
LG 50PA4500 50" 4500 Series Plasma HDTV Questions & Answers
LG 50 inch plasma wont power on?
U can chk the fuses in the back but it is poss u have shorted it out and it will need to go in to a TV service company. Mine was about us $ 150 to fix. I touched the satelite wire against the back grill of the tv briefly but this was enough. Dont forget to chk that u r getting power off the power switch it is plugged into. Also if it is plugged into something else chk that this is providing power out as it has fuses too. cheers.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
