20 Most Recent NetGear WG511 54Mbps 802.11g Wireless PC Card (NTWLNGWG511N) Questions & Answers
Driver netgear
To download the drivers for the adapter, visit the link below:
http://kb.netgear.com/app/answers/detail/a_id/753
6/20/2009 8:07:15 AM • NetGear WG511... • Answered on Jun 20, 2009
Enable nighthawk 5g on laptop
Your wireless adapter, the one in your laptop, the laptop we know nothing about because... well who knows why you would withhold that vital bit of information, all I can do is speculate, and speculation is usually counter-productive, and I answer questions on this board to be productive, so what I am getting around to say is that the aforementioned wireless adapter, the one in your laptop, needs to be 5 GHz capable. I would know this if you cared to tell us what make and model of laptop you have as opposed to just the router which we know is 5 GHz capable because you told us. Of course, by posting in the Wireless Network Adapter forum, you can assume that we can look at your post and inherently know all the information about your problem because we are "experts".
4/23/2014 3:27:41 AM • NetGear WG... • Answered on Apr 23, 2014
0answers
G01-WPG24-A20
Be the first to answer 12/25/2013 3:16:54 AM • NetGear WG... • Posted on Dec 25, 2013Be the first to answer
Netgear wna1100 can't get it to get tronger signal
This is a simple, USB based network interface card (NIC). There's little to be changed as it is built with tiny surface mount devices that can not dissipate heat nearly as well standard through hole components can. Boosting voltages, etc will only shorten the life of the device.Locating the NIC closer to the WiFi source will improve throughput of the device. If this is not possible, increasing the height or physically reorienting it may provide some gain. The easiest way to do this is to purchase a simple USB cable that will connect to the computer's USB poert and accept the WNA1100 on the other. These cables are often available at electronics and computer stores in 3, 6 and 12 or more foot lengths for under $20 (and significantly less online). I would not purchase or connect lengths greater than 15 feet, as this is the maximum length supported by the USB standard without some sort of active repeater built in to the receiving end. By placing the WNA1100 at the end of the cable, you are free to orient it in the best position to maximize capture of the WiFi signal, regardless of the position or location of the computer.Good luck!
5/14/2012 9:04:37 PM • NetGear WG... • Answered on May 14, 2012
How To Connect With Mywifiext net Setup Page?
This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
3/11/2023 6:13:39 PM • NetGear... • Answered on Mar 11, 2023
How to check netgear r7000 speeds ?
hi please find link for how to check speed https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed
11/25/2021 1:20:54 PM • NetGear... • Answered on Nov 25, 2021
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
11/18/2021 3:59:41 PM • NetGear... • Answered on Nov 18, 2021
Belkin f9k1106v1 range extender not connecting
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer. You can also use https://192.168.206.1 to access the range extender's web-based setup page. Step 1: Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network. Step 2: Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange. Step 3: Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices. Step 4: Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected. Step 5: Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http". Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
9/12/2021 1:30:03 PM • NetGear... • Answered on Sep 12, 2021
How can i connect Netgear AC1750 Wifi Mesh Extender manually ?
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
  1. Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
  2. Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
  3. Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
  4. Accept the term and conditions, Click Continue
  5. Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
  6. Click as a Wifi Range extender
  7. Now choose the network you wish to extend and click on the Next button
  8. Enter the password of your current wifi and click next
  9. Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our extender login guide .
5/6/2021 2:30:13 PM • NetGear... • Answered on May 06, 2021
How can I check netgear extender firmware update version?
By following these simple steps you canupdate the firmware on your netgear Wi-Fi extende.
  • First of all, connect your extender to your router Connect to your extender's Wi-Fi network.
  • Visit at NETGEAR Suppor website
  • Enter your extender's Model Number or Product Name.
  • Click Downloads.
  • Select a firmware version and click Download.
  • Unzip the file if needed.
  • Enter mywifiext.ne. in your web browse.
  • Enter the extender admin user name and password.
  • Click Firmware Update.
  • Click the Browse button, then locate and select the firmware file that ends in .img or .chk.
  • Click the Upload button. The firmware update starts and the extender restarts. The firmware update process takes about two minutes.
If you still face any problem so you can watch this video :-
4/29/2021 7:59:20 AM • NetGear... • Answered on Apr 29, 2021
How do I manually update the firmware on my NETGEAR WiFi Extender?
By following these simple steps you canupdate update the firmware on your netgear Wi-Fi extende.
  • Click Downloads.
4/26/2021 3:31:43 PM • NetGear... • Answered on Apr 26, 2021
2answers
Cannot connect to NETGEAR_NET
https://www.google.com/search?q=NETGEAR_NET&oq=NETGEAR_NET&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/8/2021 5:55:57 AM • NetGear... • Answered on Apr 08, 2021
How to fix Netgear Error Code 10 on window 10 ?
  1. Click Start.
  2. Right-click My Computer and select Properties.
  3. Under System Properties, select Hardware tab and select Device Manager.
10/13/2020 6:21:48 PM • NetGear... • Answered on Oct 13, 2020
How to setup Netgear extnder setup?
https://www.youtube.com/watch?v=EkOo_gs5vBw
4/9/2020 2:36:25 PM • NetGear... • Answered on Apr 09, 2020
Netgear extender setup
https://www.google.com/search?sxsrf=ALeKk03PaBlhbIut8HXkWqf7V-HpEgzhdg%3A1585151795759&source=hp&ei=M397XuehLInDlwSL3664Aw&q=Netgear+extender+setup&oq=Netgear+extender+setup&gs_l=psy-ab.3..0l10.2265.2265..3448...2.0..0.245.245.2-1......0....2j1..gws-wiz.....10..35i362i39.kIdrteiVKc0&ved=0ahUKEwinh8zN_rXoAhWJ4YUKHYuvCzcQ4dUDCAU&uact=5#kpvalbx=_1oF7XuuSHITyasH6vLAI26
4/6/2020 1:06:30 PM • NetGear... • Answered on Apr 06, 2020
How to fix Netgear Router Password Recovery ?
To know the complete and simple steps for Netgear Router login you can contact us or visit https://router-logn.net/
3/16/2020 10:43:35 AM • NetGear... • Answered on Mar 16, 2020
How to setup Netgear WiFi Router?
go to negear.com find your router, and read the manual.. RTM what you want to do with no model stated router, is not know by us.. wifi, , Ethernet, and its firewall , or even VPNs are covered
3/16/2020 10:41:05 AM • NetGear... • Answered on Mar 16, 2020
How do I Update my Netgear Router?
Go to the Netgear website and check for the support link, go to that link and look for firmware updates for your model. They install from the computer side of the LAN, you may need to run CAT 5 cable to the inputs to do it.
12/20/2019 12:27:24 PM • NetGear... • Answered on Dec 20, 2019
Computers & Internet Logo
1 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WG NetGear
  • WG NetGear
Most Popular Question
driver netgear
  • Computers & Internet
