20 Most Recent NetGear Super G WGT624SC Router (DHWGT624SCNA) Questions & Answers
set the admin password while you enter into the router
NetGear Super G... | Answered on Jan 04, 2010
The standard keyboard in your unit does not have any internal light. There are small lights that you can but that will clip on to your screen and give you light so that you can still see your keyboard in dark rooms. You local computer store or any of the large electronic chain stores will have a number of these lights you can choose from.
NetGear Super G... | Answered on Jul 23, 2009
check if you are entering the correct wireless security in your laptop. it could be possible that the wireless security was changed.
check f wireless mac filter is enabled as well since it will not allow you to connect properly if the mac address of your laptop is not registered
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
NetGear Super G... | Answered on Nov 06, 2008
Go to netgear.com and in the support section you can download drivers and instruction manuals
NetGear Super G... | Answered on Mar 01, 2008
are other wireless devices able to connect? or is it just the laptop that is wireless?
NetGear Super G... | Answered on Dec 31, 2007
I prefer to test these problems in a step by step manner.
Have you tried to connect either the laptop or any other computer to the internet using an ethernet cable instead of wireless?
If so could the wired computer use the internet successfully?
If so skip down to Wireless Considerations
Can you provide a web link to your internet service providers (ISP) help or support web site? If necessary will you provide you location city and state if required to access the ISP's help/support site?
Can you confirm the make and model of your router as a Netgear WT624SC?
Can you provide the manufacturer and model of your wireless adapter or the model of the Mac Laptop if it has a built-in wireless adapter?
Given that you now have a wireless network are you interested in discussing security options to protect you from people accessing your wireless network from outside your home? (if the signal is strong enough -- from inside home I can see two of my neighbors wireless routers not to mention my own)
NetGear Super G... | Answered on Dec 14, 2007
it is easy to set up encryption to stop your connection being tapped into, but its your option as to whether you use wep wpa-psk or other methods, so refer to this manual http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf#xml=http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=4520295&action_code=6&highlight_info=352321905,0,12&turl=http%3A%2F%2Fkbserver.netgear.com%2Fpdf%2Fwgt624v3_ref_manual_25Apr05.pdf&answer_id=9504347
NetGear Super G... | Answered on Jun 10, 2007
Go to the web based interface, should be accessible by typing this address. 198.162.1.1 . Once there look for the security tab where it will ask you to choose wap or wep. Choose wep if available it's more secure, from there just follow the instructions to set a SSD and password .
READ THE DIRECTIONS THEY PROVIDED YOU
NetGear... | Answered Yesterday
How To Setup Netgear Wifi Range Extender.....
You can use NETGEAR Extenders in two modes; one is extender mode and other is access point mode. The first mode usually expands the incoming signals from router in far corners of home or workplace, whereas the second mode makes extender work as a WiFi hot-spot. Here are the instructions to install NETGEAR WiFi Range Extender as an access point:
Go to the Netgear website and check for the support link, go to that link and look for firmware updates for your model. They install from the computer side of the LAN, you may need to run CAT 5 cable to the inputs to do it.
NetGear... | Answered on Dec 20, 2019
DO YOU HATE ALL THE SPAMMERS AND SPAMMING HERE ON FIXYA ??? USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449 1-845-764-4808
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS AND LETS BEAT THEM AT THEIR OWN GAME.. CARRY ON10
NetGear... | Answered on Dec 03, 2019
Manuals are available on the Netgear website, search for your particular model
https://kb.netgear.com/23517/How-do-I-set-up-my-NETGEAR-WiFi-Range-Extender
NetGear... | Answered on Nov 13, 2019
netgear vmv 3000 base
did you not mean VMB3000? google sees no VMV so....
what are you attempting to connect to what>>
a camera is that what it is?
maybe as on their web site, the designed to so...
https://community.arlo.com/t5/Arlo/how-to-setup-of-vmb3000/td-p/1212018
NetGear... | Answered on Sep 14, 2019
Hi , I was also facing same problems.I have solutions please follow some steps:
1.Restart Your Main Wireless Router And Modem.
2.Now Turn Off Your Belkin Range Extender And Wait For 20 seconds (unplug From Power)
3.Please Plug Your Extender Back To Power Outlet And Restart Your Computer.
Still Having Problems?
Don't Worry Visit here for more solutions:
Belkin Range Extender Won Connect to Wireless Router TechVaidya
NetGear... | Answered on Aug 30, 2019
To perform a factory reset:
  1. Verify that your router's Power light is on.
  2. On the back of your router, locate the Restore Factory Settings or Reset button.
  3. Use a paper clip or similar object to press and hold the Restore Factory Settings or Reset button for seven seconds.
  4. Release the Restore Factory Settings or Reset button.
    Your router resets.
When you log in to your router again, use the default login credentials:
  • User Name: admin
  • Password: password
NetGear... | Answered on Aug 18, 2019
is that a question or stinking sPAM.?
I sure can not tell.? this is spam H3LL here, so...
try using English.\?
how to find?
what is xyx?
or learn to google, bingo.
NetGear... | Answered on Jul 21, 2019
NetGear Super G WGT624SC Router (DHWGT624SCNA) Logo
10 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
netgear wirless router
  • Computers & Internet
