20 Most Recent Toshiba REGZA 52XV540U 52-Inch 1080p 120Hz LCD HDTV Questions & Answers
Lost picture is there a lamp or bulb on 52XV54OU model
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1/5/2015 4:04:23 AM • Toshiba REGZA... • Answered on Jan 05, 2015
My toshiba combi wont stay tuned in to tv to record tv programes why?
Tuning drift is the fault. you should check all the system control voltages to locate the fault. It is a skilled work. Contact any service technician. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop
9/20/2021 1:29:39 PM • Toshiba... • Answered 15 hours ago
Owners manual Toshiba SEro295
The SE-R0295 remote was sold with select Toshiba DVD/VHS recorders, including the DVR620. The manual for the recorder will have the instructions for the remote. Crutchfield has the manual for the DVR620 on the product page: https://www.crutchfield.com/S-c7W4uYBFvX6/p_052DVR620/Toshiba-DVR620.html . The current link to the manual is https://pdf.crutchfieldonline.com/ImageBank/v20101107082900/Manuals/052/052DVR620.PDF . See page 12 and subsequent pages for information on using the remote. This does not appear to be a universal remote that can control other devices besides the DVD/VHS recorder. I hope this helps. Cindy Wells
9/13/2021 7:02:34 PM • Toshiba... • Answered on Sep 13, 2021
Toshiba B-EV4D firmware
Do not waste countless hours on your college assignments anymore. Get <a href=" https://speedygrade.com/p/test-bank-for-biochemistry-4-e-4th-edition/ ">Test Bank For Biochemistry 4 E 4th Edition</a> and work smart with better results.
9/9/2021 8:50:56 AM • Toshiba... • Answered on Sep 09, 2021
Model 46XV540U TV. Why is backlight out?
The back light and the LCD in your TV has burned out and had quit working and the screen for your TV will have to be replaced.
8/23/2021 8:13:06 AM • Toshiba... • Answered on Aug 23, 2021
I have a Toshiba 40ft1u tv that needs a main board 461C2P51L12' 431C2P51L12' STF32T' VTV-L32606
Here is a board, it's from Canada but with shipping is not to bad priced at $60. I know nothing about the seller so it's possible you could get a defective board. I assume your missing the ps_on signal from the main and that's why the set won't turn on
8/22/2021 1:59:06 PM • Toshiba... • Answered on Aug 22, 2021
My Toshiba TV VCR Combination has sound but no picture, just snowy
What color cables are you using?
7/29/2021 9:00:48 PM • Toshiba... • Answered on Jul 29, 2021
I have uet-606 universal remote control, but i
Buy another one on Ebay universal remote control5.00 dollars from china
7/20/2021 11:54:00 AM • Toshiba... • Answered on Jul 20, 2021
2answers
Toshiba 65H83 is flickering after maybe an hour on. Is this a convergence chip issue?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile. Mobile View has no search box.
6/27/2021 3:32:49 PM • Toshiba... • Answered on Jun 27, 2021
My Toshiba 52hm95 dlp TV has a fast blinking red light and a slower blinking green light. Just replaced the bulb and clueless on what the problem might be.
Try cleaning the fans, especially the fan that cools the light box.
6/20/2021 12:04:08 PM • Toshiba... • Answered on Jun 20, 2021
Toshiba 50hp66 screen flashes. sound is good. you can see picture in the background
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/
5/16/2021 1:55:21 PM • Toshiba... • Answered on May 16, 2021
Toshiba Tv code in model Mega MG-404
https://universalremote.codes/toshiba/
5/12/2021 6:57:54 PM • Toshiba... • Answered on May 12, 2021
2answers
I have a Toshiba DVR620KU DVD Recorder/VCR which is 8 years old and the power will not stay on. The power stays on for 10-15 seconds before shutting off. Any idea what could be wrong with unit?
Sounds like some thing short circuit at its circuit board. Short circuit protection activates, as the set is switched on. Contact any service technician to check and find out the fault. This is not a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
4/23/2021 5:42:11 AM • Toshiba... • Answered on Apr 23, 2021
How do I program my Toshiba ct877 remote to work sceptre television??
The CT877 remote was included with several Toshiba TVs, including the 26DF56. Thus the programming codes for the remote are in the TV manual on pages 16-17. This manual is available on the support page: https://support.dynabook.com/support/staticContentDetail?contentId=2844172&isFromTOCLink=false . The current link to the manual is https://content.us.dynabook.com/content/support/manuals/userguides/su2844172/xxdf56_om_e.pdf . It does not have any codes to control other TVs. A universal remote that was programmed six months after your Spectre TV was manufactured would probably be a better solution for you. I hope this helps. Cindy Wells
1/23/2021 11:05:16 PM • Toshiba... • Answered on Jan 23, 2021
What is the process to code remote to a TV for ct877 Toshiba remote
I think you need to contact there customer support or read the manual.Visit https://www.frogbridgedaycamp.com/
1/23/2021 10:30:59 AM • Toshiba... • Answered on Jan 23, 2021
2answers
We have a Toshiba Blue Ray which we have used for viewing Netflix. Two days ago it stopped allowing us to view - we also tried our WII and it does not allow on this either. What's wrong
This sounds like a problem either with your internet/network connection or Netflix. i would recommend a few steps to isolate where the problem is: Step 1. Use another device, e.g. tablet, pc or laptop on the same network as your Blueray device/WII and see if you can connect to Netflix. ** If you cannot connect to Netflix, go to step 2. ** If you can connect, Netflix is fine, the issue is with the connection between your router/modem and the Bluray/WII console. Go to step 2. Step 2. Take your laptop/ tablet and connect to another network, a friends or neighbors, or a hotspot from your phone. Then try to connect to Netflix. ** If you are able to connect and watch Netflix, the issue is with your network. Go to step 3 If you are unable to connect to Netflix, you may have a problem with your account. Contact Netflix support, who are normally very good at trouble shooting the problem. Step 3. ** On the Bluray and Wii, disconnect from the network and forget this network. ** Next power off your modem and router, wait 10 minutes and power them back up again, modem first, then the router. ** Once all the right light are steady on both the modem and router, try to connect either the Bluray or Wii to the network and see if you can get Netflix to work. If yes, you are in luck! If no, you may need help from an internet professional or the 1-800 support line of your router manufacturer. Hope that helps.
1/21/2021 9:29:34 AM • Toshiba... • Answered on Jan 21, 2021
Model 46RU530U. Why does picture stay on for a minute or two, then go off?
Your LED backlights are bad
1/15/2021 9:18:37 PM • Toshiba... • Answered on Jan 15, 2021
Toshiba REGZA 52XV540U 52-Inch 1080p 120Hz LCD HDTV Logo
3 questions posted
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
lost picture lamp or bulb 52xv54ou model
  • Televison & Video
