20 Most Recent
OEM Systems Motorola Bluetooth Headset H500 [OEM] , Baby Pink Headset Questions & Answers
Motorola h500 bluetooth headset
Make sure the wall socket it's plugged into is on. Some have wall switches that must be turned on to activate the socket. Leave it plugged in over night if you are using it the first time. Plug something else into the socket (like a desk lamp) to make sure it is delivering electricity.
If it still doesn't turn on after attempting to charge with an electrical socket you know works, the product may be defective.
Bluetooth snyc problem
I'm going to find my solution somewhere else (probably the manufacturer) b/c they won't charge me $10 to get useless advice from a bunch of amateurs.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
