20 Most Recent Maytag MTF2155GRQ Top Freezer Refrigerator Questions & Answers
If you are not getting any water to the ice maker, I would assume that the little blue thing is in fact the water solenoid. These are replaceable at most appliance parts houses.
Maytag... | Answered on Mar 19, 2009
Make sure their is no stray ice cubes jamming the ice maker. If they are then zap em with a hair dryer. Fill the ice maker with water and wait. if it kicks out a batch change the water valve. if it don't kick nine out change out the ice mold thermostat. None of this is very hard to fix. One other thing is if those condenser coils are clogged with lint then the ice maker won't get down to 25 f and the ice mold thermostat won't start the harvest.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Maytag... | Answered on Mar 02, 2009
Switch off frig and let it completely defrost.
Maytag... | Answered on Jun 27, 2008
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Maytag... | Answered on Apr 23, 2008
MOST ALL MANUALS GIVE DIRECTIONS FOR MORE THAN ONE MODEL INCLUDING FEATURES THAT MAY NOT BE ON YOUR MODEL. SOME DO NOT HAVE ADJUSTABLE ROLLERS BUT INSTEAD HAVE A FIXED ROLLER AND A SET OF LEGS TO BE SCREWED INTO THE SOCKET AT THE FRONT CORNERS AND ADJUSTMENTS MADE WITH THE LEGS.
Maytag... | Answered on Apr 11, 2008
probably better off getting a new fridge. replacement could cost £150-250 depending on the engineer replacing it.
Maytag... | Answered on Mar 16, 2008
test the supply with a meter
Maytag... | Answered on Dec 23, 2019
YOU GENTLY SQUEEZE THE PLASTIC TO GET IT OUT OF THE WAY
Maytag... | Answered on Dec 13, 2019
Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
Maytag... | Answered on Oct 01, 2019
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
Maytag... | Answered on Sep 17, 2019
Is icemaker switched on. Usually located near icemaker/ Or maybe faulty switch
PLEASE CHECK THE CONNECTION CAREFULLY AND THEREAFTER IF NOT WORK THEN CONTACT TO WELL MACHANIC.
Maytag... | Answered on Sep 15, 2019
Maytag MTF2155GRQ Top Freezer Refrigerator Logo
6 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
ice maker not working
  • Refrigerators
