20 Most Recent RCA 20F511T TV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
RCA 20F511T TV • Answered on Mar 12, 2015
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
RCA 20F511T TV • Answered on Jan 10, 2014
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
RCA 20F511T TV • Answered on Jul 09, 2012
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
RCA 20F511T TV • Answered on May 20, 2012
with tv off press and hold both CH- and Vol- at same time untill tv comes on you should now be in service menu.
RCA 20F511T TV • Answered on Apr 02, 2012
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
RCA 20F511T TV • Answered on Feb 28, 2011
Hello
Try this
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
RCA 20F511T TV • Answered on Nov 08, 2010
I suggest that it may have a power supply fault and was just hanging on and has now failed.
Contact the manufacturer for the details of the nearest dealer.
Hope you get it going soon.
RCA 20F511T TV • Answered on Nov 04, 2010
you have a problem in the vertical section of tv, take your fist and hit the top of the tv, if it flickers or fills out you have loose solder joints which is common in that model, if not you need a tv repairman. not to expensive to repair normally
RCA 20F511T TV • Answered on Jul 29, 2010
If it is a regular TV which is what the model number listed suggests, the problem is in the vertical circuit of the set. Confirm the model number for me and also an approximate cost of the set when new.
I need more information to help you correctly.
SD TECH--I am here to help.
RCA 20F511T TV • Answered on Mar 25, 2010
you have a problem on the neck board of your tv there are three transistors there that mix the colousr check them and change the defective one if that does not solve your problem ic 301 on the circuit board is defective replace it.but you re not a tech have a tech do your repairs.good luck.
RCA 20F511T TV • Answered on Feb 27, 2010
YOU HAVE TO REPLACE CAPS IN VERTICAL SECTION
RCA 20F511T TV • Answered on Feb 09, 2010
Hit the menu button and it will let you in to turn FPA off.
RCA 20F511T TV • Answered on Dec 21, 2009
Hit the menu button and turn FPA off.
RCA 20F511T TV Logo
Popular Tags
53 questions posted
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca television gos off channel surfs
  • Televison & Video
