20 Most Recent RCA 27V520T 27" TV Questions & Answers
0answers
HALVE OF SCREEN
You posted this in the wrong category. Use the correct one to get an answer
1/14/2014 11:59:47 PM • RCA 27V520T 27"... • Answered on Jan 14, 2014
Remote code comcast
038,031,039,033. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
10/11/2013 9:40:19 AM • RCA 27V520T 27"... • Answered on Oct 11, 2013
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
12/29/2012 6:55:52 PM • RCA 27V520T 27"... • Answered on Dec 29, 2012
TV doesn't turn on.
Seek tech support
6/3/2012 3:06:57 PM • RCA 27V520T 27"... • Answered on Jun 03, 2012
I push the on button tv turns on then it turns off
Know this group of sets well: before you turn it on with it plugged in do you hear any odd buzz from the set? (with set off)These sets with this issue 95% of the time have a bad sweep transistor (shorted) and a bad High Voltage Transformer--sounds serious but with Generic parts cost for parts would be under 30 dollars--about 30 minutes to locate and replace same.Questions?
4/6/2012 9:04:40 PM • RCA 27V520T 27"... • Answered on Apr 06, 2012
Accidently locked the fpa using
Hello
Without its original remote control it is difficult to unlock your RCA tv. If you haven't one, try to get it from any one amoung your friends who owns your model for just to unlock your TV. If you can do this, inform me by Fixya. I'll send you the proceedings to unlock your RCA TV. ok.
3/4/2011 4:18:45 PM • RCA 27V520T 27"... • Answered on Mar 04, 2011
Just bought a used older model rca tv parental
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
1/3/2011 6:02:59 AM • RCA 27V520T 27"... • Answered on Jan 03, 2011
Turned on the fpa lock
You maybe able to unplug the tv for sometime and wait awhile then plug it back in and this might possiblly reset it.You can look to the users manual to check or go to the rca website and see if they can give you a solution. Or if you look carefully with a fine tooth comb on the back of the tv panel there might be a little hole that maybe a pen can fit into that will say reset.but not all tvs have that feature.Sorry i didnt have a better solution for you. But i hope this helps you out. Good luck !!!
1/2/2011 11:56:24 PM • RCA 27V520T 27"... • Answered on Jan 02, 2011
I just bought an RCA
It may not be possible to get off the TV but try the code 0000, 1234, 1111, 7777, and 9999. Many times these are default lock codes. Also, what is the model # of the TV, it should be on the back on a label on the TV..
Please let me know and I can help more, but first try those codes. If we can't get it off I hope you can still return the TV.
Thanks, just reply to my answer here and I can help.
Tim
11/3/2010 2:55:38 PM • RCA 27V520T 27"... • Answered on Nov 03, 2010
4answers
RCA 27V412T TV Problem
Just to see if the set reacts and it does something different tap the sides of it,dont over do it ,I should not take much to see a reaccion if it has a loose conection,If it reacts check for loose conections in the power supply,horizontal driver transformer and any overheated areas specially after the output transformer.If you are familiar with tv service this should help but if you are not be safe and call for assistance from a servicer.
10/21/2010 1:30:24 AM • RCA 27V520T 27"... • Answered on Oct 21, 2010
RCA 27V520T 27" TV has a red tint
Keep down the colour completley, and note whether you get a pure black and white picture. If not adjust the cutoff control, normally these are preset controls fitted on the base card of the TV; to adjust the excess colour seen on the screen to increase or decrease; so that you can get a clean black and white pocture with no tint on it. it is a time taking task; and should have some sort of skill and more patience. Sometimes you may have to retune other two cutof controls [Blue and Green], too to get the desired effect.
10/17/2010 5:01:11 AM • RCA 27V520T 27"... • Answered on Oct 17, 2010
2answers
Is there an online guide
Hello. If all you are looking for is a photo of this tv, here it is
27rcatv.jpgJoe
4/21/2010 8:18:43 AM • RCA 27V520T 27"... • Answered on Apr 21, 2010
Tv goes off and on its has a picture and sound
well it will had a loose contact inside,,, or horizontal driver transformer may be faultered
3/23/2010 6:20:53 PM • RCA 27V520T 27"... • Answered on Mar 23, 2010
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
3/7/2010 10:17:42 AM • RCA 27V520T 27"... • Answered on Mar 07, 2010
WANT TO HOOK UP MY SONS PLAYSTATION 2 BUT WHEN I
You have to put you TV in AV Mode. You don't use the "Channels Tuner" on this type of input. But use Audio Visual Mode.
2/6/2010 1:54:45 AM • RCA 27V520T 27"... • Answered on Feb 06, 2010
Rca 27v412t has sound but no picture. what can i
Are you technically inclined ? If you are then you may want to check for cold solder connections on your driver transformer.
12/16/2009 4:10:59 PM • RCA 27V520T 27"... • Answered on Dec 16, 2009
Tv popping with lines horizontally but does not do
Poor TV reception or if it's the tuner put a cable box and bypass the tuner
9/28/2009 1:04:53 AM • RCA 27V520T 27"... • Answered on Sep 28, 2009
Televison & Video Logo
68 questions posted
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
tv turns off while watching
  • Televison & Video
