20 Most Recent RCA Lyra RD2763 MP3 Player Questions & Answers
What is 72 times 2.51?
180.72
10/1/2010 7:43:12 PM • RCA Lyra RD2763... • Answered on Oct 01, 2010
Hello i was wondering how to clear the songs out
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visable.
Hold the left click down and drag it across all the files/songs that you do not want this will hightlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
11/3/2009 7:01:29 PM • RCA Lyra RD2763... • Answered on Nov 03, 2009
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
10/14/2009 3:55:36 AM • RCA Lyra RD2763... • Answered on Oct 14, 2009
7answers
File system corruption
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
7/21/2009 5:03:34 PM • RCA Lyra RD2763... • Answered on Jul 21, 2009
How many songs can i put on my RCA
Depending on the length of the songs and the type of format the songs are in you can get anywhere from about 1000-2500 songs.
6/4/2009 5:46:00 PM • RCA Lyra RD2763... • Answered on Jun 04, 2009
Battery
Sounds simple, but you need a new battery.
4/9/2009 4:28:06 AM • RCA Lyra RD2763... • Answered on Apr 09, 2009
2answers
Why cant i put songs i removed back on
This player can only handle songs that are in a specific bit rate - lower it to the rate suggested in your product specs. Go to RCA's website if you have lost the documentation. Corrupt file systems can usually be solved with a firmware upgrade (also at RCA's website), but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
3/28/2009 10:20:31 PM • RCA Lyra RD2763... • Answered on Mar 28, 2009
2answers
Rca lyra rd2765a
When this happened to my unit I had to have it replaced by RCA.  Fortunately mine was under warranty at the time.  About 2 years ago when this happened the RCA rep told me that the unit has a fairly low capacity for shock.  So if you dropped it this could be the issue.
1/19/2009 3:54:11 AM • RCA Lyra RD2763... • Answered on Jan 19, 2009
3answers
RCA Lyra H125
Hay 1 solución segura hay que desarmarlo y con tooooodo el cuidado del mundo sacal el disco duro o microdrive, hay unas computadoras que tienene la ranura para el micro drive (md) lo conectas ahy y lo formateas, el problema que yo tuve es que tuve que conseguir la carpeta lyra_sys que se encuentra oculta en el mp3.
Asi que si alguien tiene la carpeta, podria facilitarmela.
Gracias
11/15/2008 4:59:25 AM • RCA Lyra RD2763... • Answered on Nov 15, 2008
2answers
Hard disk temperature too low!
I had the same problem on my daughter's Lyra 5GB MP3 player. I fully charged it, tried the 10 second power button reset, and was on the way to remove the back to check the disk drive cable when my daughter dropped it and it started working again!
Good job too, since when I checked, the disk drive connector appeared to be soldered on.
10/13/2008 4:59:31 PM • RCA Lyra RD2763... • Answered on Oct 13, 2008
RCA H125A decrypt error!
Get the latest firmware upgrade from RCA's website
7/26/2008 11:46:50 PM • RCA Lyra RD2763... • Answered on Jul 26, 2008
FILE SYSTEM ERROR MESSAGE
Glue = bad
Put the player back together and do this:
-Tha Mp3 Doctor
7/6/2008 1:04:04 AM • RCA Lyra RD2763... • Answered on Jul 06, 2008
RCA H125A
That could be a hardware failure - requiring replacement, but go to the RCA website and get the Recovery tool. I'm assuming that you already tried resetting the player. If RCA's methods fail, try this:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
7/6/2008 1:02:46 AM • RCA Lyra RD2763... • Answered on Jul 06, 2008
My RCA LYRa is having issues!!!
http://www.fixya.com/support/t126039-file_system_corruption
(H115A)
Had "File System Corrupt!" message appear on my RCA H115A after a bit over a year. PC wouldn't recognize it, and it wouldn't stay turned on.
Following advice (thanks folks), I uncovered the screw under the barcode and popped the back with the help of my knife. I didn't notice that the connection from the hard drive was loose, but pulled it out, wiped everything off, and reconnected. It worked!
They don't give this at the help desk, but it seems to be a common problem with many models. Looks like the connection isn't very tight.
6/27/2008 6:33:42 PM • RCA Lyra RD2763... • Answered on Jun 27, 2008
My mp3 player is frozen
yea just hold it down for a while until it turns off buddy!! thats wat i did lalex i got it like a couple of mins after i posted
6/5/2008 7:48:14 PM • RCA Lyra RD2763... • Answered on Jun 05, 2008
4answers
File system corrupted!
get a new hard drive;if no warranty; open the mp3and reset hard drive directly
3/2/2008 9:35:40 PM • RCA Lyra RD2763... • Answered on Mar 02, 2008
Rca H106A 6GB player
Sometimes all you need to do for that is profile the songs. This organizes the songs into the correct catagories.
12/26/2007 3:53:29 AM • RCA Lyra RD2763... • Answered on Dec 26, 2007
Rca 4 gig mp3 player siries rd2762b wont turn on system file curpted
12/20/2007 7:17:27 AM • RCA Lyra RD2763... • Answered on Dec 20, 2007
System file corrupted
12/20/2007 7:17:12 AM • RCA Lyra RD2763... • Answered on Dec 20, 2007
RCA Lyra RD2763 MP3 Player Logo
Popular Tags
48 questions posted
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
many songs put rca
  • Audio Players & Recorders
