20 Most Recent RCA Lyra RD2317 (1 GB) MP3 Player Questions & Answers
I think I deleted my recording software or something??just can't play my mp3's..player turns on when I plug into computer but will just continue loading when I try play it
RCA Lyra RD2317... | Answered on Nov 06, 2008
Remember when you format memory like a hard drive you erase everything. Move music to your internal mp3 memory and do a profile - folders should appear. If you have flashed your player with the firmware update you can get 520 songs on the player for both internal and external combined but be warned that if you exceed this count your player will start to forget the earlier loaded songs - listed but not addressable (playable). The same is for the folder count eg. add album = artist + ablum title (min 2 folders). Plus always profile your songs after loading new music or deleting as this is an index build process to play song 152 = title x. This includes accidental radio recordings to MP3s. RD2312 , RD2315, RD2317 Lyra™ mp3 flash player Firmware/Application Upgrade Version 3.11 fixes:
  • Supports a total of 520 songs, in up to 50 folders, with up to 8 levels of subfolders.
RCA Lyra RD2317... | Answered on Jan 16, 2008
Did you have more detail to the question? Seems to be missing something at the end. Please Edit the question or Add Information or Comment to flesh it out
What in specific are you hooking the microphone into?
Amplifier, preamp, mixer, receiver?
It will depend what your input is expecting
Have you put in new batteries in the mic?
Do you see that the receiver is receiving the mic signal?
Is there any sound at all when you plug the output of the receiver into the input of your { fill in the blank } ?
Setup guide
https://www.akg.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw3aa903a6/pdfs/AKG_WMS40_Mini2_Quickstart_Guide.pdf
RCA Audio... | Answered on Nov 14, 2019
DVD players normally don't have amps built into them. If you need to connect the DVD to amp (AV) then it will need to be connected either via an RF lead connected via RCA sockets marked RF OUT on the DVD player and one on the AV marked RF IN. If the AV has an optical in, then you can connect the DVD to that for better quality sound. You might also need to change the sound output settings on the DVD player to the correct one you are using.
Missing speaking sounds are the result of a lack of a centre channel speaker. If your AV doesn't have one. Then you will have to use the stereo only setting.
If the DVD player is only currently connected via the standard RCA left and right jacks, you will only get stereo sound.
RCA Audio... | Answered on Oct 12, 2019
If you're trying to put an equaliser in between a source and an preamp or integrated amp, the amp needs to have tape OUT or dubbing OUT connections. This will go to the eq's IN. Then eq OUTs should be connected to the tape or dubbing IN on the amp. When playing any source you set the amp's source selector to tape or dubbing IN and now what you are hearing is coming through the equaliser.
RCA Audio... | Answered on Oct 05, 2019
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_0.jpg For more details, check: How to Download Music from YouTube to iPod
RCA Audio... | Answered on Sep 19, 2019
RCA Lyra RD2317 (1 GB) MP3 Player Logo
6 questions posted
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
rca lyra rd2317
  • Audio Players & Recorders
