20 Most Recent Ricoh AC205 All-In-One Laser Printer Questions & Answers
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Ricoh AC205... | Answered on Jan 21, 2011
try to remove the toner by following the procedures stated on your own manual. Do not forget to turn off the power and remove its cables. Try to align the toner in such a way that it will be exactly set to it. Then align the paper to its tray and try to print. COnsult Ricoh if symptom persists
Ricoh AC205... | Answered on Nov 20, 2010
lift the lid ull see a **** glass that needs to be cleaned any mark on it will be shown as a black line
Ricoh AC205... | Answered on Nov 05, 2010
Your problem may be a simple as paper dust.
Take all the covers off get a can of canned air and blow out everywhere you can reach especially in the areas where there are or my be sensors. Be careful not to spay to much in one place or you'll end up with condensation and then condensation problems.
Ricoh AC205... | Answered on Jun 14, 2010
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
Ricoh AC205... | Answered on May 17, 2010
The scanner lock is not due to paper jam.. There is a dedicated knob provided for lock /Unlock the scanner.
To unlock the scanner,
1)Gently pull the scan lock label until it comes away from the machine. This will pull the scanner locking switch into the FORWARD (Unlocked) position automatically.
After Unlocking press Clear/Stop Button.
I hope this solves your problem.
Thanks
Ricoh AC205... | Answered on Feb 14, 2010
In order to exit this error checks out for a blue latch in this section. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, the scanning unit assembly needs replaced.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Ricoh AC205... | Answered on Feb 06, 2010
Yup thats what it probably is..that and/or bad power ripple.
Ricoh AC205... | Answered on Jan 27, 2010
Donload printer river here, postscript driver and printer switcher here:
http://www.ricoh-usa.com/solutions/common/universalprintdriver/default.asp
Ricoh AC205... | Answered on Dec 23, 2009
It is problem you copier exproser lamp mirror.Please clean it by soft cloth then solve your problem
Ricoh AC205... | Answered on Sep 12, 2009
You have a fuser error. Unplug the machine and try again. If you still get the error, then you'll need to replace it.
Ricoh AC205... | Answered on Apr 20, 2009
In the print output tray there is a green lever that locks the scan bed in place. Move this lever and the problem should be resolved.
Ricoh AC205... | Answered on Mar 28, 2009
The only reason they shouldn't print is due to a technical problem. There are no error messages or red lights at all?? That's very strange.
It must be a software glitch of some sort. You can do a memory clear to empty it out and perhaps restore the proper functioning, but it does set the machine right back to factory defaults, so you will have some settings to restore afterward.
You can get the manual here if you don't have it. Memory reset procedure is on page 8.2:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/ac205/ac205en.htm
Ricoh AC205... | Answered on Mar 05, 2009
Go into the menu, then Maintenance, Clear Settings, and clear all settings. You will have to re-adjust everything, but this worked fine for me.
If you have any questions, you can email me at Rav3nsFan [at] gmail.com
Ricoh AC205... | Answered on Jul 29, 2008
Make a phone call to your Ricoh service rep and report code SC 556.
Ricoh Office... | Answered on Sep 21, 2020
93300
HRB (Head Relay Board)
fuse blown
Mounted on the top part of the carriage unit.
Ricoh Office... | Answered on Sep 15, 2020
Ricoh AC205 All-In-One Laser Printer Logo
20 questions posted
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
install ac205 usb
  • Office Equipment & Supplies
