20 Most Recent Maytag MZD2768G Side by Side Refrigerator Questions & Answers
Could be defrost board pn 61005988 abt. $90 or Defrost heater and thermostat pn WP 61006199 abt. $60.
You can find parts and instructions by going to partsselect.com and it will give you some diagnostics and installation instructions, if you enter model no. In their search engine.
Maytag MZD2768G... | Answered on Jul 02, 2017
Sounds like an inefficient compressor or possible overload/relay issue
Maytag MZD2768G... | Answered on Jul 26, 2013
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Maytag MZD2768G... | Answered on Oct 04, 2011
Tested impedence on compressor, and got nearly 0 on all terminals. Short story - Replaced starter kit with another;if didn't work, take cover off to look at coils and found the compressor and fans were not on. Unplugged and replugged and if everything will started ok.
and if otherwise, Refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. If the compressor starts, replace the defrost timer. For further help, you'll want to call a professional appliance repair technician.
Sometimes you can hear a click-buzz-click sound coming from the compressor. This is the relay/overload at work. If you hear this, power is getting to the compressor. If you do, something is wrong with either the compressor or the compressor starting components. If you have a newer model with solid-state starting components, you may not hear anything at all. If there is power to the starting components, you may be able to test each part and replace any bad parts. There is also a 3-in-1 unit that may work on your model which replaces all the components in one unit. If the compressor still won't start, you have a bad compressor and need to replace it. If it does start, wire the 3-in-1 part in permanently. Make sure the one you buy is rated for the horsepower of your appliance.
If you don't hear anything, you can take the cover off the side of the compressor and test for voltage at the two leads. If no voltage is present, it's time to check the cold control. To test if the cold control is bad, you can temporarily jump the two wires at the cold control. If you get power to the compressor after doing so, the cold control needs to be replaced.
I hope this will help to solve the problem...
Maytag MZD2768G... | Answered on Sep 19, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Maytag MZD2768G... | Answered on Jan 16, 2011
most of the time the fill line is out of alignment or the unit is not level and it is spilling over on one edge you can level it by loosening the screws that hold it mounted to the left side of the fridge. also make sure the water is not dripping after it turns off. Hope this helps and good luck.
Maytag MZD2768G... | Answered on Aug 16, 2010
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Maytag MZD2768G... | Answered on May 24, 2010
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Maytag MZD2768G... | Answered on Jan 08, 2010
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Maytag MZD2768G... | Answered on Sep 30, 2009
you have a clogged evap drain, you need to take the back panell off the freezer and pour boiling water down the drain port until it flows freely
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Maytag MZD2768G... | Answered on Jun 13, 2008
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Maytag MZD2768G... | Answered on Dec 31, 2007
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Maytag MZD2768G... | Answered on Aug 14, 2007
Fridge keeps beepingor buzzing:The following is for Frigidairemodels but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls
  • A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open
  • When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
  • The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset
  • A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Maytag... | Answered on Mar 26, 2020
There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping
Maytag... | Answered on Mar 10, 2020
Maytag MZD2768G Side by Side Refrigerator Logo
Popular Tags
22 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pierre Laplante
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag mzd2768geb
  • Refrigerators
