Step one is to try hooking up your monitor to a different computer. If that does not yield a different result then it is likely going to be a problem with the power circuit in the monitor.
If your monitor is still under warranty then you should be ok, if not then you can contact Samsung for help by using
THIS webform.
You may also be able to get this fixed at a local TV repair shop, but you best answer, considering the smallish size of that monitor would be to go buy a new one. Many decent LCD monitors can be had for about $100.
http://ars.samsung.com/customer/form/formmail/usa/input_SEA.jsp?SITE_ID=1&PROD_ID=28
