20 Most Recent Samsung SyncMaster 550S Monitor Questions & Answers
You can try lowering the refresh rate to a lower value. Ex. from 100Hz to 60Hz
Samsung... • Answered on Mar 23, 2019
Take it into a repair shop and say a capacitor has gone. It isn't a big job. The part itself is a couple of $
Samsung... • Answered on Jan 10, 2018
very possible that you will have to down load the driver screen get the samsung web site up find the model of the screen and the operating system on the computer and download it
Samsung... • Answered on Dec 07, 2017
Here are the instructions to open the monitor:
http://josepino.com/?open-samsung-back-cover
"Don't kill yourself just to save some bucks"
Good luck.
Samsung... • Answered on Apr 25, 2014
BAD NEWS THE PICTURE TUBE IS WEAK THE ONLY FIX IS TO REPLACE YOUR MONITOR WITH A NEW ONE
Samsung... • Answered on Oct 07, 2011
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Samsung... • Answered on Jan 17, 2011
Try using the brighten controls in the monitor.
Samsung... • Answered on Oct 17, 2010
That is caused by absence of the vertical signal, more likely to be a problem with a semiconductor (specially a transistor) broken inside the display. Also, it may be caused by a "cold joint" or a problem with the solder. Heat caused by the "excessive" use of this monitor causes the joint to fail.
Samsung... • Answered on Sep 06, 2009
It's easy to open, just insert a flat screwdriver in each top slot and push it until it "clicks".
Complete instructions and photos at:
Good luck.
Samsung... • Answered on Sep 04, 2009
How do you change the bulb on viewsonic monitor 19" model VX900? Where can I get a new replacement bulb?
Samsung... • Answered on Sep 12, 2008
5 year old hyjacker, vinay. you forgot to say connected to what? is the screen only dim or dead.? even more important clue. RTM read page PDF 17, ? the OSD screen must work or the monitor is dead http://downloadcenter.samsung.com/content/UM/201205/20120517112305649/SA10-04Eng.PDF base pages https://www.samsung.com/us/support/owners/product/lcd-monitor-a10-series
Samsung... • Answered on Sep 12, 2018
Press the auto key of your monitor to get the best fitted resolution for your window, each monitor has a limited graphic capability of which it is designed. if the production is not ok consult your manufacturer.
Samsung... • Answered on Jul 05, 2016
Samsung SyncMaster 550S Monitor Logo
23 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
remove cover viewsonic vx 900 monitor
  • Computers & Internet
