20 Most Recent
SAMTRON 96B 19" CRT .22MM 1600X1200 Monitor Questions & Answers
Samtron monitor is heaving control lock problem
d problem is in a transistor costing little, situated near d monitor's
osd control ic (microprocessor), it is probably short....[refer the
connection n area around the front panel cn connector and crystal clock
generator]..beware u must b a professional
10/29/2009 6:44:29 AM •
Samtron...
Answered
on Oct 29, 2009
Socket Information
They are inputs: Red, Green, Blue, Horizontal & Vertical.
Monitor Mike
1/21/2009 11:15:33 PM •
Samtron...
Answered
on Jan 21, 2009
Monitor Samtron after 10min. looses contact with computer
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
1/12/2009 7:18:56 PM •
Samtron...
Answered
on Jan 12, 2009
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3.
Unplug power cable from LCD, Once power cable is unplugged from LCD,
press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
10/6/2008 8:44:40 AM •
Samtron...
Answered
on Oct 06, 2008
Monitor connection
there is a great possibility that your resolution or refresh rates are set too high for the monitor to display properly... boot the computer in safe mode and change the resolution and refresh rates to a lower setting or the recomended setting for the monitor.. 73 and good luck.
9/17/2008 8:51:36 PM •
Samtron...
Answered
on Sep 17, 2008
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
