20 Most Recent
Samsung SyncMaster 150MP Monitor Questions & Answers
Power button blinks - won't turn on
When the power light blinks, it indicates in PC mode that there's no PC signal (depending on the monitor, it could be the sync signals or a combination of sync and video.)
You SHOULD be able to hit the source button to see if the monitor then comes up to allow you to watch another source like the S-Video, Video or TV (ok, so good luck picking up any signals if you're in the US -- but you SHOULD see static and this is probably the best "quick test" for now).
If you see static... your monitor works for most part.
Where you would troubleshoot now is the cable for your PC and the connector to the monitor on both the PC and and the monitor end. These can come loose, get abused and cause solder breaks on the circuitboards within (less common but possible).
Most cable issues I see are just bad cables from extremely tight spaces bending the cable and causing wiring breaks in the connector housings. (unrepairable because of the molded cable end)
Try those out and let me know.
-Ben
11/7/2011 12:47:52 AM •
Samsung...
Answered
on Nov 07, 2011
Sync out of range message
This monitor (supposedly) only supports the following ranges:
Horizontal Rate (KHz)
30-70
Vertical Rate (Hz)
56-85
29.8K < 30K (although darn close).
This is usually fixed in the settings for your graphics card. Are you running Windows or Linux?
If Windows: You can load up the drivers for the monitor (I never do) or choose to hardwire the monitor to a VGA LCD 1024x768 and then even force the vertical refresh to 75Hz (or something nice). Try that.
In Linux (under Xwindows), you'll need to look at the /etc/X11/xorg.conf (if using that) and change the section for the monitor to include the limits as shown above.
Do a "man xorg.conf" for the parms. They're also on Xorg's website.
12/11/2009 9:41:52 PM •
Samsung...
Answered
on Dec 11, 2009
Popping static noise SyncMaster 150mp
Are you still having problems with this monitor?
I posted about a "clicking" sound that has to do with failed capacitors near the speakers' amplifier IC.
If this is your problem, let me know - it can be fixed.
Check this article: http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
-Ben
12/11/2009 9:38:11 PM •
Samsung...
Answered
on Dec 11, 2009
Power button lights, doesnt blink, but no other
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
8/8/2009 12:37:34 PM •
Samsung...
Answered
on Aug 08, 2009
Clicking sound
I found the problem.
I've written up a small article on my website detailing the fix but in summary here:
Electrolytic Capacitors C826 and C835 go bad because of the heat stress applied by the audio amplifier right below them. Replacing those capacitors fixed my 150MP.
For more information see:
3/3/2009 4:53:46 PM •
Samsung...
Answered
on Mar 03, 2009
Internal Speakers
The speakers are fairly small and might be easy to replace if you surf the surplus sites.
If you are not comfortable disassembling the unit, I would call the manufacturer.
Otherwise, you can check the TDA7268 IC (amplifier for speakers) on the circuit board the speakers
plug into with a scope.
I recently fixed my monitor and noted how hot that chip gets (and it supposed to) with the possibly incorrect or inadequate heat sinking Samsung designed into the circuit board that cause my monitor to fail. (although differently)
You can email me too if you're still having problems with this. The design is pretty straightforward and could be tested to some degree with a multimeter.
Regards,
--Ben
10/17/2008 1:45:17 AM •
Samsung...
Answered
on Oct 17, 2008
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
