20 Most Recent Samsung SyncMaster 920N 19" LCD Monitor Questions & Answers
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Samsung... | Answered on Jan 26, 2013
Here are two options to try:
National Parts Depot 800-469-4800
Spare Parts Warehouse 877-253-8898
Hope one of them has what you need.
Samsung... | Answered on Jan 18, 2012
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
The flashing power button is an indication that the power supply has failed. There are parts called capacitors that filter the output power and when they short out the power supply can't start up correctly os it tried over and over, this make the power light flash each time it tries to start up. The monitor is easy to repair if you can do a little soldering. Here is a link to a repair guide that will show you how to dis-assemble the unit and what to look for and replace to get it back going again. Te guide also has videos showing the steps.
BuddyMc
This may due to power supply is not connected properly or power supply itself gone bad. check and repair/replace the power supply may solve your problem.
Revert back for assistance.
Hello Dfrank,
The 920N units use the same power supply board that the 710T uses and it was a known issue with bad capacitors that fail. When they fail it can cause the issues that you are having - Either slow to show a picture, wavy display or no power and flashing power light. The boards can be repaired if you can do a little soldering, the parts are cheap. We have a step by step repair guide posted on our tech support web site at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/ This is an easy repair for a very nice monitor, well worth repairing it.
BuddyMc
Samsung... | Answered on Aug 08, 2011
try to use another monitor data cable
good luck
Samsung... | Answered on Apr 20, 2011
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung... | Answered on Mar 25, 2011
It wants you to set the PC video reolsution to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Will the old program let you run the PC video resolution at 1280 x 1024 @60Hz?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Samsung... | Answered on Jan 12, 2011
I have exactly the same problem with the same monitor.
And I have no solution. Please help.Thank you
Samsung... | Answered on Jan 06, 2011
Check the video cable and also try it with another PC first, if it still does not work then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Samsung... | Answered on Oct 02, 2010
you can't be serious...um...you need a new computer bro
Samsung... | Answered on Sep 13, 2010
Well there are many things you need to check -
first of all check all the cables connected with monitor (VGA or DVI or HDMI) may be the cable are bad or loose connection.
then check the ground wire may be bad,
then try using another monitor with your computer.
post further comments for more help or information .....
Good Luck!!
Thanks
Samsung... | Answered on Oct 12, 2009
LCD usually doesnt require a driver, it is plug and play
Samsung... | Answered on Jul 14, 2009
Samsung SyncMaster 920N 19" LCD Monitor Logo
41 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
syncmaster 920n 5 minutes
  • Computers & Internet
