20 Most Recent
Samsung ML-3561ND Laser Printer Questions & Answers
ML 3561ND engine fuser. low heat error??????
If you have annother tonner cartridge, (the old one will do)fix it and see if it works. If not there might be a component faillure related to the Fuser Unit. Also check for any Jam in the Pinions(Sometimes Samsung Laser Displays wrong MSG.)
Samsung...
Answered
on Feb 27, 2010
Paper jam 1. Fuser rollers not rotating.
Hope this helps, We had a similar problem with a brother colour laser.
If you carefully remove the fuser rollers and toner cartridge grab a moist/damp cloth soaked dishwashing soap, not to wet but and carefully wipe down the fuser rolsers and toner rollers.
Remember toner is toxic so be carefull
Be carefull not to nick the rollers, if anything chips it or scratches it it will mark everything else.
And yes envelopes if fed incorrectly can gum up the rollers.
I have also used metho to carefully clean down all the rollers before just dont use too much.
Another handy tip is follow the path that a sheet of paper travels and watch where it gets caught exactly.
IF you do pull it all apart, Just make sure you take it slow and watch where everything goes to put it all back. Also make sure that you discharge the unit before opening it up so there is no high voltage inside.
Also if you find that the toothed clutch is worn chek out ebay for spares for your model.
Cheers
Hope this helps
Steve
Samsung...
Answered
on May 28, 2009
Fuser Door/s
Your Samsung ML-3561ND looks to be an HP Laserjet 4000-series printer. Same engine, different electronic.
The fuser is in the rear of the machine, and may be relating to the drop-down rear panel where you clear paper jams. Open it and give it a good push closed and the printer should cycle and come ready.
Let me know what happens!
Samsung...
Answered
on Feb 11, 2009
Samsung 3561ND fails to print double sided.
Do you use the duplexer a lot? It sounds as if the rollers inside need to be cleaned.
I don't recommend doing this yourself as it involves lifting the printer off of the duplexer, and I don't want to be responsible if you accidentally drop the printer or you or someone gets hurt. But that's how to get to it; the offending rollers should be visible, and may be cleaned with a clean rag moistened with a multi-purpose cleaner. Alcohol is what's recommended, but I shy away from it as it's known to dry the rubber, and all you want to do it clean the built-up dirt and paper duct off of it.
Let me know how it works, if you do it! If you opt not to, call a qualified printer technician.
Samsung...
Answered
on May 29, 2007
Location of Solenoid samsung ML-2510 printer
Pick-up SOLENOID needs replacing.
See this link.
http://www.arbikas.com/view/locator/ML-2510.pdf
Part is JC33-00015B SOLENOID-MP_R2;-,SCX-4720F,DC24V
Fairly involved strip down but there are a Cpl of you tube videos out there showing something similar.
Looking to undertake this task myself and will You Tube it.
Samsung ML...
Answered
on Jul 25, 2016
