20 Most Recent Samsung SpinPoint T133 Series (HD300LD) 300 GB Hard Drive Questions & Answers
It could be the enclosure itself. I would try that first, especially if you have data you are trying to recover. or it could be that it was running NTFS and it was improperly removed. If you don't have anything you are trying to recover, you could just reformat it. JUST REMEMBER: Reformatting will erase any data on the drive.
Samsung... • Answered on Oct 03, 2017
The hardware that you are trying to access is damaged or failing. The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure connection and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Samsung... • Answered on Feb 13, 2013
if you just need the data of this hard drive you might need USB 2.0 To SATA IDE 3.5 2.5 Hard Drive Adapter Cable kit i have one of these myself and they work a must have to retrieve any data of my old hard drives cheap recovery$8.69 + Aus 95c postagehttp://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress http://www.paypal.com/ be very specific when you type in the search always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described you will even see the pictures of your item so you cant make a mistake and get them home delivered hope this helps you
Samsung... • Answered on Apr 14, 2012
Hallo,
Druk op de toets SUBT op de afstandsbediening.
Vervolgens kan via de toets TOOLS de instelling voor ondertiteling worden aangepast.
Samsung... • Answered on Jan 24, 2010
To download songs just go to the website from where u want to download song then there should be download button around a song to download.Just click on it and your download starts.
thanx
Samsung... • Answered on Mar 31, 2021
1 Turn on the computer, then press the F4 key several times before the Samsung logo appears to open Samsung Recovery. 2 Click Computer Factory Reset 3 Click the Start Factory Reset button. 4 When the Start reset confirmation screen appears, click OK. 5 Your PC is reset. (Please note: resetting may take some time, depending on your PC.) 6 When a message appears saying reset is complete, click the OK button. 7 The PC will restart. 8 Finish setting up your PC according to the on-screen instructions. 9 After rebooting, check that your PC has been reset correctly.
Samsung... • Answered on Mar 27, 2021
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Samsung... • Answered on Mar 08, 2021
check junk folder , check spam folder smart tv uses what system ? google android ? download app to tv from playstore if android system ??
Samsung... • Answered on Feb 12, 2021
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue. I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.) On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates. I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem. Cindy Wells
Samsung... • Answered on Oct 20, 2020
Resolve the issue of Error Code 0xc0000185 with the help of the Hp Technical Support Phone number. Here the Technical Expert will provide you all possible help for getting out of this issue. Just visit the help website through the link shown below. Link:- https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-0xc0000185
Samsung... • Answered on Sep 11, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily cheaper that new modems and routers
Samsung... • Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port? If so then try and plug it in that way. Try and reset the router and tv Make sure the connection settings are correct or defaulted Are you entering the correct password? Are you close enough to the router? reset the network setting on the tv it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail. Mr.Mike
Samsung... • Answered on May 20, 2020
Download and install this it will allow almost all media to play in your windows media player.
http://download.cnet.com/K-Lite-Codec-Pack-Full/3000-13632_4-64246.html?tag=mncol;2
Or you could download VLC media player, it plays everything.
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=mncol;1
Personally I would stick with the windows media player, just because it's half a part of windows, & it's what I've always used. Or if you have a zune, or xbox windows media player is needed.
Samsung... • Answered on Apr 28, 2020
hi. my name is rui i will answer your question regarding your problem about how to setup a compatible dvd decoder for sumsung external dvd drive.
1st of what's the model of yoursumsung external dvd drive?
2nd if you have a internet connection and know the model of your dvd drive you can download a compatible decoder for your sumsung(model)using google.
here is one that you can try out its a NVIDIA PureVideo Decoder (NVIDIA DVD Decoder) 1.02.186 (Samsung Dvd Decoder).
NVIDIA PureVideo Decoder is a combination of a hardware video processor and video decode software for playback of DVD and MPEG-2 videos using Microsoft Windows Media Player and Windows Media Center Edition.
you can download it @ http://samsung-dvd-decoder.fyxm.net/
it's easy to use just follow the instruction...
hope it helps you in anyway.^_^
Samsung... • Answered on Apr 07, 2020
Samsung SpinPoint T133 Series (HD300LD) 300 GB Hard Drive Logo
8 questions posted
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Spinpoint Samsung
  • Spinpoint Samsung
Most Popular Question
samsung fried
  • Computers & Internet
