20 Most Recent Samsung TX-R3080WH 30" TV Questions & Answers
0answers
TV turns off after a few seconds
it could be the bulb on the way out, they don't like to turn on if the inverter does not get a voltage use from the bulb, while trying to turn on the tv look at the vents for the bulb if you see it flicker on and of while trying to turn on the tv when it would be the bulb. when the tv is on and work hold a peace of paper over the vent not to cover it but to look at the bulb light if you see a flicker or bright and dim and repeats doing this then the bulb is warn out. if you hear clicking or scratching sounds this could be the inverter board on it way out.
7/3/2017 3:03:59 PM • Samsung... • Answered on Jul 03, 2017
I have a Samsung TX-R3080WH CRT TV that when you t...
tv samsung modelotxs-3082whx/xaa mi problema queel tv se ve como desenfoca posible falla el escreen
7/24/2016 6:51:22 AM • Samsung... • Answered on Jul 24, 2016
When i turn the T.V on it turns right back off
The capacitors on the power board have most likely blown
Simply re solder new caps in place of the ones that have buldged on top
If you have soldering iron and skills you can do it yourself
The parts will only cost you about £2
a TV shop will charge you £80
4/5/2011 3:14:54 PM • Samsung... • Answered on Apr 05, 2011
Buzzing sound after warm-up won't
This problems are comming from the power supply board it iself.That the board,where the power a/c cord plug into it.Tries putting in supper glues all over the those big tranformers on the power supply board to cover up those gaps for exscapping high pitch current humming.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
1/27/2011 3:32:25 PM • Samsung... • Answered on Jan 27, 2011
Yesterday the picture was clear in in the middle
the cables in the backpart of the tv may be bad connected to resolve this problem reconect them again or just check the manuals for help
1/26/2010 1:24:27 AM • Samsung... • Answered on Jan 26, 2010
Samsung TX-R3080WH, tv is less than 2 years old
not sure about this model but it sounds like the backlight has gone out. You can call samsung at 1-800-samsung and they may be able to help or give you the # of the nearest service center.
12/8/2009 10:53:22 PM • Samsung... • Answered on Dec 08, 2009
SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
9/2/2009 2:22:46 AM • Samsung... • Answered on Sep 02, 2009
Turn it on, no picture for a while. Then picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
7/29/2009 4:35:54 AM • Samsung... • Answered on Jul 29, 2009
My tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
7/22/2009 10:01:22 PM • Samsung... • Answered on Jul 22, 2009
Red Vertical line across tv screen.
remove and reseat the system board if that doesn't cure it replace the system board part number AA94-15695A get it at www.vancebaldwin.com price $158.90.
this is what the board looks like
5/6/2009 2:35:15 AM • Samsung... • Answered on May 06, 2009
4answers
I bought my Samsung TX R3080WH, 30 inch tv in Sept
Sounds like the capacitors in your power supply had burnt out causing to high of a voltage which can cause a threat to other system boards and components. You will need to have your power supply tested firstly.
3/10/2009 1:29:04 PM • Samsung... • Answered on Mar 10, 2009
Turns off and on with no help from me
are you a technician if so go to the relay circuit and fix that circuit more than likely has bad ic like the eprom .
are leaky transistor also check the power button for lose connection they are tiny little switches now a day
2/22/2009 4:07:03 AM • Samsung... • Answered on Feb 22, 2009
No picture
Bad solder connects....needs chassis pull,careful soldering..
not the picture tube.....................T.
11/26/2008 4:10:07 PM • Samsung... • Answered on Nov 26, 2008
2answers
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
5/23/2008 5:09:41 PM • Samsung... • Answered on May 23, 2008
Dropped TV
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
5/3/2008 3:46:41 PM • Samsung... • Answered on May 03, 2008
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
2/27/2008 12:50:49 AM • Samsung... • Answered on Feb 27, 2008
Samsung TX-R3080WH 30" TV Logo
28 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
tx r3080wh 30 tv i have a samsung tx r30
  • Televison & Video
