20 Most Recent
Samsung HL-R7178W 71" HDTV Questions & Answers
I replace a new Philips
Hello... I would start by getting the correct lamp for the TV, and I would advise getting an original equipment lamp. The lamps and ballasts are matched by wattage and operating voltage, and a mis-match will at best cause early lamp failure. The sound you are hearing could be the ballast trying to ignite a bad lamp caused by a mis-match. I hope this helps!
11/26/2017 11:57:16 PM •
Samsung...
Answered
on Nov 26, 2017
I have red bars of different widths running
Hi
You have a ground loop problem. Rolling shaded bars are the classic sign of a ground loop. Your TV & AV gear are likely not on the same
ground level as the input cable line. The cable line is likely floating
to a different ground. But this is not hard to fix.
3/14/2011 1:53:35 AM •
Samsung...
Answered
on Mar 14, 2011
Black strip left side of the screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
4/30/2010 5:23:15 PM •
Samsung...
Answered
on Apr 30, 2010
My Samsung HL-R7178 rear projection tv is
sounds like this could be an issue with the color wheel or in the dmd board that is what controls the color but with the vibrating I would start with the color wheel look for any cracks or broken parts of it
1/25/2010 4:21:01 PM •
Samsung...
Answered
on Jan 25, 2010
On my hls5679w the tv
HLS5679W has power supply issues. Two capacitors need to be replaced as Samsung put in units of the wrong voltage...
CM860 and CS860 need to be at least 2000mfd/25vdc radial (both leads come from one end) electrolytic capacitors. It is recommended to have a service tech do this you'll need to pull the power supply out of the set. Parts are cheap (Radio Shack for about $2.99 or so each) but you must be able to solder to replace...
3/28/2009 9:47:42 PM •
Samsung...
Answered
on Mar 28, 2009
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
