20 Most Recent
Samsung HT-Q70 Home Theater System System Questions & Answers
When a movie is playing, you can hear all sounds
The voices are probably coming out on one of the channels that has a bad speaker, bad wire, loose connector, or bad output. If you have the audio set to 5.1 output, change it to two-channel stereo output. The voices should return to normal.
Everytime I turn my on samsung ht-q70 the display
The amplifier has a bad channel, or is bad itself. It is trying to
either output too much current or is not putting out enough. If you have
multiple speakers wired to one channel, you will either have to change
the wiring to series(unit positive to first speaker red, first red to
second BLACK, second red to unit negative) or remove on speaker. (If
this is the case, then you might want to look at
this. It is a tip/rick to place and
properly/successfully run three subwoofers, but the main concept can be
used on all channels.) If all channels are wired to he correct speaker,
then the amp is in fact at fault.
Upgrading DVD quality
Hi.
It displays 480i or 480p because that is the maximum resolution of a DVD. DVD cannot go over that limit.That is already improved to the max.
To get an higher resolution you need to use blue ray.
My Samsung HT-Q70 5 disc drawer won't stay closed.
make sure its fully cleaned. many appliances will automaticly open the disktray if there is a reading error. DO NOT TOUCH THE LENS. i suggest a simple blow over the lens and cleaning the disk, try again. if all else fails, contact your seller and get a trade in.
Swa3000
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
- With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
I just want to know if I can connect my laptop to
Yes you can and it is very simple. All you need is a special wire. One end fits to the earphone jack on the laptop, and the other end looks like rca cable. At the back of your home theater choose aux in, and connect the rca end of the cable to that. Then the other end looks like a headphone jack, and you connect that to the laptop headphone jack. Now on you home theater select aux. You will everything that comeout of that laptop including the windows vista melody when you first boot it up. Now you are ready to enjoy music.
How do i connect/play my turntable?
Hi sorry to say cant go direct.
What you can do if really want it running is get a RIAA pre amp with power supply (search google local shops). The turn table plugs into that, then that plugs into one of the analogue inputs of the Q70. That will work great if prepared for the effort!
Best of luck
Can't get the disc drawer to open/ close
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
