20 Most Recent D-Link Dlink Dir-600 Wireless Router Access Point Broadband Internet Switch Questions & Answers
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
D-Link Dlink... | Answered on Jan 31, 2017
If your PC, iPad and smartphone work well with your router, the problem is with your chromecast. If can't set it up to work with the routes, I guess that it's "wireless adapter" or whatever makes it work, is defective. If it's new, you should return it to the shop where you bought it, should have warranty
D-Link Dlink... | Answered on Dec 22, 2016
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
D-Link Dlink... | Answered on May 11, 2015
Make the other person get their own Internet access, rather than sharing your access.
D-Link Dlink... | Answered on May 07, 2015
Why? What sites?
Login to the router's internal web-server, and click the "Advanced" tab, and enter the IP-addresses of the sites you want to block.
I think you are saying that when the router is wireless it disconnects and when you plug it in via Ethernet it never disconnects. This is a common occurrence. You might also be saying that your are bypassing the router and plugging the Ethernet from the cable or DSL modem directly into your PC. In any case you can try the diagnostics below:
First try the easy obvious fixes.
How far away are you from the wireless router when it is disconnecting? Try putting them next to each other when you are connected wirelessly. If they don't disconnect then the problem is they are too far apart. If the problem is resolved, try putting the router half as far away and see if it is OK at that distance. If the problem is a distance problem, put the router up higher or closer to your PC, or try moving the antennas around if there are antennae. This will look funny, but you can also put a sheet of aluminum foil on the side of the router opposite the PC, so the router is in between the foil and the PC, it will reflect the signal back to the router, and that might strengthen the signal enough.
It can also be interference from other electronic devices. Try putting the wireless router away from everything by at least 2 or 3 feet and see if that solves the problem.
It can also be a heat issue, make sure the wireless has enough air circulating around it. I had a router once that would overheat and then disconnect, then cool down and reconnect. I couldn't get that router to ever work correctly, it overheated often, so I upgraded to another wireless.
If none of those above helped ...
Then it has something to do with either the wireless router, or the wireless adapter on your PC. Do other devices also disconnect every hour? Can you borrow someone else laptop and see if they disconnect every hour also, if so then it is the router.
Now you have to get the router manual out because this will get a little advanced, what you want to do is update the router firmware if it needs it. First check what version of the firmware you have on the router. You can do this usually by clicking here in this browser on your PC http://192.168.1.1 if that doesn't work try this http://192.168.0.1 if that doesn't work read the manual and see what the address is to check the firmware of your router. Usually you will use your browser and type in a number similar to the one above. You will need a username and password to login to the router. Find the version number of the firmware that you have loaded on this router. Write that down.
Look at the back of the router, write down the exact model number and version of the wireless router. They usually will have a version. Now search for that model number and version and also for the words "firmware download". If this version is newer then download it to your PC. If it is newer then start the router firmware upgrade process. Plug the router directly into the PC with an Ethernet cable, connect to the router thru the Ethernet only using the 192.168.X.X address above. (probably need to disable wireless on the PC to make sure it is going thru the Ethernet). read the manual how to backup the router. Back it up to the PC if you can. Or write down all the settings and passwords on paper. But backup somehow. Double triple check you got the right firmware for the right model. Now read thoroughly how to upgrade the firmware for your model router, not always, but usually a matter of going to the right page inside the router, then click on upgrade firmware and browse to the firmware file you downloaded above. Then make sure you wait till the upgrade process is complete. Do not disturb it while it is in process. OK, now after rebooting the router check if the connection is stable.
If that didn't work then you can do a similar process for your PC and see if your wireless adapter needs to have the firmware updated, but usually it gets updated when the PC does, but check anyway.
If none of the above work, then time for a new router. Luckily they are not too expensive. If after you buy a new router you still have issues then sorry, it was probably the PC.
D-Link Dlink... | Answered on Sep 21, 2014
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
D-Link Dlink... | Answered on Nov 06, 2013
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
D-Link Dlink... | Answered on Oct 24, 2013
Try This:
Enter the SSID pass code. If that does not work reset your D-Link to Factory Default settings
See Blow:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
D-Link Dlink... | Answered on Aug 09, 2012
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
D-Link Dlink... | Answered on Jun 29, 2012
access violation in module Uimain.exe at address oo6F6AB6
read address 000002EC
Computers &... | Answered on Feb 13, 2020
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
D-Link Computers... | Answered on Dec 19, 2019
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
D-Link Computers... | Answered on Dec 12, 2019
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-Link Computers... | Answered on Dec 04, 2019
You can get best d-link router support phone number at Toll Free Number ( 1-877-769-0969 ). D-link router Tech Support number ( 1-877-769-0969 )
D-Link Computers... | Answered on Nov 12, 2019
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
D-Link Computers... | Answered on Nov 11, 2019
KATHERINE, Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
D-Link Computers... | Answered on Oct 26, 2019
SUSAN, Your message does not qualify as a question or query for a problem, try somewhere else
D-Link Computers... | Answered on Oct 19, 2019
D-Link Dlink Dir-600 Wireless Router Access Point Broadband Internet Switch Logo
18 questions posted
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
enable multicast chromecast dlink 600
  • Computers & Internet
