20 Most Recent
Maytag MSD2736GR Side by Side Refrigerator Questions & Answers
Good afternoon, we just had our power turned back
Hi!
I know this may sound weird, but you should try to wash it with vinegar, plain vinegar will do the trick.
Also, I don't know if you have this in your country, but sour lemon it is good too, for this kind of situations.
After this treatment it is applied, wash it with a cleaning solution mixed with water, then rinse with simple water.
I hope this will help you!
Have a nice day!
*please don't forget to rate my services :)
Maytag MSD2736GR...
Answered
on Sep 02, 2011
Maytag 12858102 refrig side is
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Maytag MSD2736GR...
Answered
on Aug 01, 2011
Got it gave to me temp set at 1 on frezzer 0
I have looked up your unit and have some questions. Is there frost in the freezer? If so how much? Do you have air flow to the refrigerator section coming in from the top left? This model has a defrost timer located in the control area of the refrigerator section and you can manual advance it to verify defrost cycle if need be. I would need those questions answered to assist you further....
Thanks
kidlmo
I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
Maytag MSD2736GR...
Answered
on Jul 23, 2011
Ice buildup in freezer drip pan and water overflow
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Maytag MSD2736GR...
Answered
on Sep 21, 2009
