20 Most Recent
Sony Ericsson HBH-610a Headset Questions & Answers
Sony Ericson 250i Headset not recognised
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Can a wireless headset be used with NEC SL1100 Phone
The NEC SL1100 phone can be used with a wireless headset, but it will require a specific type of connection.
The NEC SL1100 phone has a 2.5mm headset jack, which is not compatible with most wireless headsets, which typically use a USB or Bluetooth connection.
To use a wireless headset with the NEC SL1100 phone, you will need a USB-to-2.5mm headset adapter or a Bluetooth-to-2.5mm headset adapter.
The Plantronics CS50 wireless headset is not directly compatible with the NEC SL1100 phone. However, Plantronics offers a USB-to-2.5mm headset adapter which can be used with the CS50.
It's worth noting that some NEC SL1100 phones are equipped with a built-in Bluetooth module, which allows you to connect a Bluetooth headset directly. To check if your NEC SL1100 phone has this feature, you can check the user manual or contact the manufacturer.
It's important to check the compatibility of the wireless headset and the phone system, before making any purchase. It's recommended to consult the manual of the phone system or the technical support of the phone system provider to ensure that the wireless headset you plan to purchase is compatible with the phone system.
1/28/2023 12:43:05 AM •
Radio...
Answered
Yesterday
I need the wiring code for rd104e mic to DNT Strato 1 Din 8 Pin
The wiring code for an RD104E microphone to a DNT Strato 1 Din 8 Pin radio will vary depending on the specific models and manufacturers. It's recommended to check the user manual or the technical specifications of the microphone and the radio to find the correct wiring code.
Here is a general wiring code for RD104E Microphone to 8 pin DIN connector:
Pin 1 - Audio Pin 2 - PTT (Push to Talk) Pin 3 - N/C (No Connection) Pin 4 - N/C (No Connection) Pin 5 - N/C (No Connection) Pin 6 - N/C (No Connection) Pin 7 - Ground Pin 8 - +V (Power)
Keep in mind that this wiring code is a general one, and it may not work for your specific microphone and radio. So, it is highly recommended to check the user manual or the technical specifications of the microphone and the radio to find the correct wiring code.
Also, it's important to make sure that the voltage and amperage requirements of the microphone are compatible with the radio's power supply.
1/28/2023 12:37:47 AM •
Radio...
Answered
Yesterday
I have a FT-747GX that won't transmit
If your FT-747GX is not transmitting when you press the PTT button, there are a few things you can try to troubleshoot the issue:
- Check the settings: Make sure that the transmitter is set to the correct frequency, mode, and power level. Also, check that the mic gain and RF power settings are adjusted correctly.
- Check the antenna connection: Make sure that the antenna is properly connected to the radio and that there are no loose connections.
- Check the power supply: Make sure that the radio is receiving adequate power and that the power supply is functioning properly.
- Check for software updates: Make sure that your device has the latest software updates installed.
- Check for interference: Make sure that your device is not too close to other electronic devices that may be causing interference.
- Check the values of the voltage on the main board, as you mentioned, the values of 4.5 and 0 for RX and 0 and 1.4 on TX, it could be possible that one of them is too low or high, which can cause the issue.
- Check the PTT switch, and make sure that it is working properly and not stuck.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting a transmitter can vary depending on the model and manufacturer.
1/28/2023 12:36:26 AM •
Radio...
Answered
Yesterday
Rino 650 ppt button not working
If the PPT (Push-To-Talk) button on your Rino 650 is not working, there are a few things you can try to troubleshoot the issue:
- Check the battery: Make sure that the battery is fully charged and properly installed in the device.
- Check the settings: Make sure that the device is set to the correct frequency and that the PTT button is configured correctly in the settings.
- Check the physical button: Make sure that the PTT button is not stuck or damaged in any way.
- Check the programming: Make sure that the device is properly programmed with the correct settings, including the correct channels and frequencies.
- Check if the device is in a low power mode, if so, switch it to high power mode.
It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting a PTT button can vary depending on the model and manufacturer.
1/28/2023 12:34:40 AM •
Radio...
Answered
Yesterday
In gp339, when we press ptt switch, no tx, how to solve
It sounds like you are having an issue with your GP339 radio where the PTT (Push-To-Talk) switch is not transmitting when pressed. Here are a few potential solutions to try:
- Check the battery: Make sure that the battery is fully charged and properly installed in the radio.
- Check the antenna: Make sure that the antenna is properly connected and not damaged.
- Check the settings: Make sure that the radio is set to the correct frequency and that the PTT switch is configured correctly in the settings.
- Check the microphone: Make sure that the microphone is properly connected and not damaged.
- Check the programming: Make sure that the radio is properly programmed with the correct settings, including the correct channels and frequencies.
- Check for physical damage: Make sure that the radio does not have any physical damage, such as a broken switch or damaged wiring.
- Check that the radio is programmed for the correct channel.
- Check that the radio is not in "Low Power" mode, if so, switch it to "high power" mode.
If these steps do not resolve the issue, it may be necessary to contact the manufacturer or a professional radio technician for further assistance.
1/28/2023 12:31:22 AM •
Radio...
Answered
Yesterday
Chrysler 2013 300c uconnect bluetooth is not working showing " Bluetooth pairing not successful". I can't even add new device.
There are a few things you can try to troubleshoot this issue with your 2013 Chrysler 300c's Uconnect Bluetooth system:
- Make sure that your phone's Bluetooth is turned on and that it is in pairing mode.
- Check the Uconnect system's settings to ensure that Bluetooth is turned on and that it is set to discoverable mode.
- Try restarting both the Uconnect system and your phone to see if that resolves the issue.
- Check the vehicle's manual to see if there are any specific instructions for pairing a device with the Uconnect system.
- If the above steps don't work, try clearing the Uconnect system's memory of previously paired devices, and then try pairing your phone again.
- Check if the software of the Uconnect system is up-to-date, if not update the software.
- Try deleting all previously paired devices on the Uconnect system, and then try pairing your phone.
If none of these steps resolve the issue, it may be a problem with the Uconnect system itself and you may need to take your vehicle to a Chrysler dealership for further assistance.
1/27/2023 9:04:07 PM •
Radio...
Answered
Yesterday
Tvbp-btn wireless stereo headset. Cannot get it to charge & show blue light. Shows red light when plug into charger; light goes out approx 1 minute later.
If your TVBP-BTN wireless stereo headset is not charging properly and the blue light is not showing, there are a few things you can check to fix the problem.
- Check the charger: Make sure that the charger is functioning properly and that the connections are secure. Try using a different charger or USB port to see if that resolves the issue.
- Check the charging port: Make sure that the charging port on the headset is not dirty or blocked. Clean it with a dry cloth if necessary.
- Check the battery: Make sure that the battery is not damaged or dead. If the battery is damaged or dead, the headset will not charge.
- Check for software updates: Make sure that your headset's firmware is up to date, if there is any updates available, install it.
- Check the manual: Check the manual that came with the headset for any troubleshooting steps or contact the manufacturer for further assistance.
- If you have tried all of the above and the problem persists, it may be a hardware issue, and the headset may need to be repaired or replaced.
1/14/2023 10:26:47 PM •
Radio...
Answered
on Jan 14, 2023
