20 Most Recent Toshiba Tecra M4 Tablet PC Questions & Answers
I have a screen problem. My
Toshiba is famous for overheating problems, blow out your cooling fan with canned air. Also another fairly common issue with the M4 is memory module seating, basically the memory modules/sticks werent put in properly by the factory...i know..go figure. Remove the memory panel from the back of the unit and remove the memory stick/s. Should be 2 of them, be gentle, and then just simply reinstall them back where they were making sure they are seated in the slots firmly, then replace the memory cover and fire it back up. This worked on 4 or 5 ive repaired with similar issues. Hope this helps you as well.
11/8/2017 1:47:20 PM • Toshiba Tecra M4... • Answered on Nov 08, 2017
Lcd screen is black and the pc is working
computer on but screen is blank
7/15/2010 1:37:12 PM • Toshiba Tecra M4... • Answered on Jul 15, 2010
I have a toshiba tecra M4 that has a blank
For that first when you power up the computer press F8 key then if you are able see safe mode and other menu then enterin enable vga mode.
Then go to start ->control panel then display then settings .
change screen resolution to 1024*768.
Then apply and ok.
But if you are not able see any display when you power up the laptop then you have to refix
RAM memory.
Open back cover of laptop and Refix RAM memory.then if still same issue then open whole back cover and find motherbord there.
Then find motherbord and pull cmos cell from motherbord for 10 minutes then check.
Let me know if you need further assistance.
Thanks.
11/4/2009 5:09:32 PM • Toshiba Tecra M4... • Answered on Nov 04, 2009
System Crash
do a clean installation
5/16/2008 9:05:29 AM • Toshiba Tecra M4... • Answered on May 16, 2008
How can i factory reset my toshiba tablet modle wt10-a
There should be a little hole somewhere on the tablet. Stick a pin in it then it should factory reset it. Or if you can, create a new user then go to settings and factory reset it from there.
10/7/2019 2:49:20 AM • Toshiba Tablets... • Answered on Oct 07, 2019
How do I connect a Samsung tablet to a Toshiba PC?
have tried connecting with usb cable
5/13/2019 7:04:39 PM • Toshiba Tablets... • Answered on May 13, 2019
How do I pair up my tablet to my Toshiba tv
Miracast is the only way with an android device unless your Toshiba TV has file sharing/media sharing apps on it.
1/10/2019 5:57:23 AM • Toshiba Tablets... • Answered on Jan 10, 2019
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
12/24/2017 9:07:03 AM • Toshiba Tablets... • Answered on Dec 24, 2017
Toshiba Tecra M4 Tablet PC Logo
Popular Tags
16 questions posted
Top Toshiba Tablets & eReaders Experts
David Shaub
Steve
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
M4 Toshiba
  • M4 Toshiba
Most Popular Question
screen problem
  • Tablets & eReaders
