20 Most Recent Toshiba Tecra M4-S435 Tablet PC Questions & Answers
I have a toshiba tecra
Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer. If you report that to the Toshiba Technical personnel, they can transcribe the error number for you. If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
1/11/2018 10:27:57 PM • Toshiba Tecra... • Answered on Jan 11, 2018
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached. 1st. make sure the volume is up all the way. Then try using a headphone just to make sure the sound card is working. If the headphones work then it should be a setting somewhere. Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing. If they don't work the sound card may be blown but it is still possible it is not. Also, try Keyboard shortcuts for mute and UN-mute. Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there. If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
9/28/2017 3:39:46 PM • Toshiba Tecra... • Answered on Sep 28, 2017
PCI express error
Unfortunately this is a very broad error, i suggest you contact Toshiba support on this one,
Which could lead too your motherboard been replaced.
2/2/2016 7:49:08 AM • Toshiba Tecra... • Answered on Feb 02, 2016
2answers
I installed windows xp on
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
10/14/2013 10:19:34 PM • Toshiba Tecra... • Answered on Oct 14, 2013
I have a toshiba tecra m4-s435. i plug it in to
you can try also format your toshiba tecra m4-s435 and
8/27/2011 2:28:37 PM • Toshiba Tecra... • Answered on Aug 27, 2011
2answers
Where is the location of CMOS battery on
You'll have to open up the laptop and get free access to the motherboard. Usually CMOS batteries on laptops are soldered onto the motherboard so you'll need to have some soldering skills to do this.
About the price, usually it's in the $10 range, but the best way to go is to get the original battery and visit the local wrist watch store or a specialized batteries store and ask for a replacement.
If this was helpful and informative please vote with a Thumb Up. Thank you.
5/21/2011 4:32:08 AM • Toshiba Tecra... • Answered on May 21, 2011
I replaced my Toshiba Tecra
When you replace the CMOS battery, you must wait about 10 minutes with the old battery removed, before fitting the new one (if you had a problem with the error message before) - when you fit the new battery, plug the tablet in and don't turn it on - this will give the new battery a chance to power up all of the CMOS on the board and settle down. Then turn it on, wait for the error message about the date and time being wrong, set the time correctly and the problem has gone.
1/3/2011 10:42:43 PM • Toshiba Tecra... • Answered on Jan 03, 2011
2answers
My keyboard wont type anything, the mouse works,
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
8/1/2010 8:15:14 AM • Toshiba Tecra... • Answered on Aug 01, 2010
M4-s435 bios password removal
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
6/8/2010 3:56:56 PM • Toshiba Tecra... • Answered on Jun 08, 2010
My Tecra won't turn on at all - i just got it with
If battery is charged you do not need a cable. Otherwise use the adapter that must certainly shipped with it. Plug one end of the adapter cable in the computer and the other to the wall socket.
Hope it helps.
11/29/2009 5:39:59 AM • Toshiba Tecra... • Answered on Nov 29, 2009
Laptop will not turn on. there is a virus in the
Dear Sir,
Go to http://xviruslab.blogspot.com, and download Quick Heal Total Security (PC Mobile Scan and Data Theft Protection, Anti Phishing) or Quick Heal Anti Virus Plus, mail me if you're facing any problem mail me.
Thank you
Bye bye
9/28/2009 4:55:03 PM • Toshiba Tecra... • Answered on Sep 28, 2009
When we turn on our Tecra M4 the
you need to run a program like SPINRITE.EXE . you can dl online from a torrent site. it will fix your problems.
9/12/2009 9:09:30 PM • Toshiba Tecra... • Answered on Sep 12, 2009
Estrange characters appears in my tecra m4 645 nvidia
The video card has unseated or is fried due to overheating. The typical repair is to replace the entire motherboard which will cost about US$600 from a technician. The graphics chip GPU is soldered onto the motehrboard. I ahve heard some people cooking the GPU to reflow the solder if it is an unseated GPU chip that came loose but I have not tried this myself. This is a common problem of Tecra M4's and I have been through this problem 4 times in the past 4 years, each with expensive motherboard replacements.
8/31/2009 9:25:35 AM • Toshiba Tecra... • Answered on Aug 31, 2009
No sound
4/22/2009 2:24:17 PM • Toshiba Tecra... • Answered on Apr 22, 2009
I have a virus on
http://www.sophos.com/support/disinfection/pedis.html
go to this link and your problem is solved
enjoy..........
1/8/2009 7:15:42 AM • Toshiba Tecra... • Answered on Jan 08, 2009
Search inside toshiba tecra m4
the cmos battery is nearby with the batterypack..it is connected into mainboard by using 2 wire...and it sticked into the batterypack plastic
1/4/2009 4:09:02 PM • Toshiba Tecra... • Answered on Jan 04, 2009
How can i factory reset my toshiba tablet modle wt10-a
There should be a little hole somewhere on the tablet. Stick a pin in it then it should factory reset it. Or if you can, create a new user then go to settings and factory reset it from there.
10/7/2019 2:49:20 AM • Toshiba Tablets... • Answered on Oct 07, 2019
Toshiba Tecra M4-S435 Tablet PC Logo
26 questions posted
Top Toshiba Tablets & eReaders Experts
David Shaub
Steve
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
M4 Toshiba
  • M4 Toshiba
Most Popular Question
keyboard wont type anything mouse
  • Tablets & eReaders
