20 Most Recent
Toshiba Tecra 8200 PT820U-OFG8C801 Notebook Questions & Answers
Tecra 8200 password
use bios password code for reset bios password
The CMOS is, in basic terms, the part of the
motherboard that stores the
BIOS settings. To
remove the
BIOS password from your
Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must
remove the battery from
I got a Toshiba Tecra
You have to know if the WiFi at home is “N” Network...
What you have in your Toshiba is “G”...
You will have to buy an “N” wireless USB Adapter…
Salim
Toshiba laptop tecra 8200 wifi
try on this page
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073794567&rpn=PT820U&modelFilter=8200&selCategory=2756709&selFamily=1073768664
My laptop suddenly crashed and it is not turning on
1. Pull the RAM and Reseat it..
2. Check the Fan/Heatsink to see if Clogged
3. Check AC Adapter with a multimeter to see if it's supplying power
4. Check DC Jack on the motherboard (the port where your Charger Plug Plugs into)
Will not turn on
Hi there.
Try taking the battery out and turn it on using the AC power only.
Laptop crashed
if u have not changed ur hard disk just want to restore ur system from a crashed windows u can do it as below without any cd actually a safe copy of OS is kept at a location in the original hard drive that came with ur laptop just try this and all will be ok
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
it will install the operating system as it was the day u bought the notebook
pls rate me if u find me fixing ur problem
Tecra 8200
Download a program called Netstumbler.
This will show if your wireless is doing anything at all firstly.
If the card is internal then check if the wireless cards antenna's are connected still. Sometimes they are not on there correctly, just sitting there and look like they are connected.
If you can see the access point with this program then check the router to see if the access method hasn't been limited locking out your card from connecting. Normally that is listed in the wireless access list by MAC address etc.
Networking is more complex then most realise, but the info above should help you to start with.
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
