20 Most Recent
Toshiba Portege S100-S1133 Notebook Questions & Answers
Hi i have a portege
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Installing XP on Toshiba Portege R500 Notebook
Guys, if you have the genuine XP CD, please download the Storage Driver from Intel and slipstream it into your version of XP CD. You can also slipstream Service Packs into it as well.
Personally I hate Vista so much. It really brings out the angry devil in me.
By the way, the best and easiest way to slipstream is to install and use nLite
http://www.nliteos.com/
Let me know if you want help on installing XP on R500 (I build it a few days ago, but regret to update the BIOS to version 1.06 as I lost the Ctrl key on it).
To get to the BIOS, press and hold the Esc key then Power button.
Setup did not found any hard disk installed+toshiba s100-s1133
SATA HARD DRIVE - XP INSTALLATION The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
My s100-s1133 protege will not boot-up. The
This is unfortunate, as that points at a display problem which in my
experience with these laptops comes with very little chance of repair.In
my opinion it is caused by overheating of graphics processor due to the
portege's relative small build. The fix would require dissasembly of
entire laptop and re-soldering of graphics processor. This takes a
technician using a microscope equipped station,( my father does this and makes over $40 an hour and I bet his company charges more. It is not cheaper than
some new laptop models available today. The non-expensive fix but risky,
would be to disassemble board and attempt to re-flow graphics processor
connections by heating with heat gun. When I attempted this I lost
entire display. My recommendation is to use external monitor if possible,
which may prove futile since issue with graphics will likely be visible
on that too. good luck
Every time i open my lap top screen to a certain
This is unfortunate, as that points at a display problem which in my experience with these laptops comes with very little chance of repair.In my opinion it is caused by overheating of graphics processor due to the portege's relative small build. The fix would require dissasembly of entire laptop and re-soldering of graphics processor. This takes a technician using a microscope equipped station, and is not cheaper than some new laptop models available today. The non-expensive fix but risky, would be to disassemble board and attempt to re-flow graphics processor connections by heating with heat gun. When I attempted this I lost entire display. My recomendation is to use external monitor if possible, which may prove futile since issue with graphics will likely be visible on that too. good luckThe procedure involves
How to enter bios setup toshiba portege m500
Usually one of the following keys right when boot screen is viewed will get you into bios on most computers.Esc, F2, F10, Del, or F12 which should be the case with the Portege.
Want to install fresh windows
HI
this problem shows that your HDD is not recognized bye your notebook...
try this:-
- Go to the BIOS and change your hdd priority IDE to SATA, select SATA for your note book an then restart and check ..
- reconnect your hard disk on your system.
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Cant boot up my toshiba lap top. it comes up
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Tosiba Portage A100 notebok
Pasword
To reset the BIOS read the information from this
link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
My Toshiba portege R 500 wont turn on until I
According to Toshiba Support the remedy is to connect the laptop to the ac adaptor and plug in to wall outlet. Then turn it on and leave it on for 24 hours while the rtc battery charges.
Hi i am Syed Tarique
It sounds like the HDD controller may be bad.When you thought it was the OS having a problem it sounds like the controller was going out.Unless the HDD you were connecting to it was bad.
