20 Most Recent Toshiba Satellite M45-S359 Notebook Questions & Answers
"Battery being charged" indicates that this is a laptop. Auto shutting down indicates that you are having issues with the power supply/brick. One thing to try is another known good power brick. Otherwise it is likely your power inverter inside the laptop.
Toshiba... | Answered on Jan 05, 2018
press and hold 0 on start up
Toshiba... | Answered on Apr 26, 2014
Get a reinstall driver,they are free,call Toshiba tech.service center.
Toshiba... | Answered on Oct 27, 2012
The actual switch is rare to go, the DC jack in the laptop is more likely the issue and will require a complete tear down to access.
Toshiba... | Answered on May 30, 2012
At least 2005. The drivers on Toshiba's website show the earliest date of 2005.
Toshiba... | Answered on Sep 23, 2011
you must put your password if you forget it you can send me what write on screen and may be i can help you
Toshiba... | Answered on Sep 02, 2011
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Toshiba... | Answered on Dec 13, 2010
GO to this site and enter your model number and you'll get a list of driver. Download and install
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Toshiba... | Answered on Nov 16, 2010
Are you unable to see windows scree?. Also let me know if you have disk fo operating systme
Toshiba... | Answered on Jul 29, 2010
if it is a new flash, you may half to format it first, xp and above should read any flash you plug in
Toshiba... | Answered on Mar 08, 2010
Ok, It looks like you have a DSL connection for your internet service. The problem you are having is that you are missing the WEP key inorder to connect to the modem with a secure link. The Modem has to be set to use WEP security and then there are a number of security keys that can added for security. Your modem is not configured for WEP, otherwise you would not be able to connect to it with no security.
You will have to read the information and access the modems setup features to enter the keys. You may have to go to the manufacturers web site and download the manual from it. If Verizon does not give you access to the modem for adjustment then you may need to have them setup the wep and email you the keys so you may copy and paste them into your connection configuration. Depending on the security level of the modem the longer the key the more secure. Some modems use a transmit key and a receive key in order to make the connection more secure. I would also check the modem and see if it has any options for WPA security, which are much better than the WEP. On any computer that connects to the network you have to create the connection with the WEP key or keys. If the modem uses these different keys then you have to match them. Say the modem WEP key is X to transmit and Y to receive, then the computers WEP would be set to Y to transmit and X to receive. The keys are also case sensitive numbers and letters, and the longer the better for network security. The manual will tell you the allowable maximum length you can use for the key. You can use the same key for transmit and receive if you wish to make it easier on you, but it all boils down to the type of security you programmed into the modem.
Read the owners manual for the modem and then you will have an idea what and how to get the two wireless connections to talk securely to each other. Currently your system is wide open and anyone can log on to your system without security, even the next door neighbor. Good Luck, RAC
Toshiba... | Answered on Apr 19, 2009
ok
when u power up the laptop press "del"or F2 or F5 to enter in bios .then load optimal defaults settings.then save and exit.
then check.
Toshiba... | Answered on Jan 19, 2009
well the adapter for toshiba laptop is weak, and the most common method is to use a multimeter with the electroprobes connect to the anode and cathode.if it is normal, the pointer will fix in a short time.
Toshiba... | Answered on Jan 10, 2009
Thanks for that.
Ok the onlything that springs to mind is:
1. The bios needs to be reset asit has lost settings. This could happen IF you have installedsomething OR if it has become corrupt. Just access your Biosand reload the standard default settings.
2. Your hard drivehas a fault. The best thing you can do is to boot up from youremergency floppy (if you made one) or from your original windows CD. Once done, simply run scandisk/chkdisk/defrag and let it do what itneeds.
Sorry I could not help you more, but that is the onlything I can think of that would be stopping you booting further. Personally it sounds like the bios has lost settings and may betrying to boot from another drive ... but of cause it may be thatyour hard drive has become "sticky" or has errors that arecausing the problems.
Good luck with it.
Toshiba... | Answered on Nov 23, 2008
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
Toshiba Satellite M45-S359 Notebook Logo
18 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
calibrate battery laptop toshiba
  • Computers & Internet
