20 Most Recent
Toshiba MK6034GAX (HDD2D17) 60 GB Hard Drive Questions & Answers
Hi, I have a 60
Connect the external hard drive to a the other usb port on your computer or connect it to another computer to know if its going to be recognized on the other computer or not. This will help us know where to focus our attention on.
If it works on another computer, then here is what you have to do to solve the problem:
Connect the external hard drive into your computer. Click on your "Start" menu, type in "Device Manager" under search and press enter. From the device manager, scroll down to USB, right click on your hard drive's name and select uninstall. If you don't see your hard drive's name, uninstall he USB. Remove the external hard drive, restart your computer and fix the drive back into the computer. This time, it should be recognized.
Good luck.
7/30/2010 1:07:15 PM •
Toshiba...
Answered
on Jul 30, 2010
My external hardisk is showing in device manager
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your
bios settings
2/3/2010 12:02:52 PM •
Toshiba...
Answered
on Feb 03, 2010
I have a new mk6034gax HDD from Toshiba which is
the hd has a internal registers, for oem old moterboards. you need to reset this registers and program correct values.
you may find this utilities on toshiba website on service
area
11/27/2009 11:17:23 PM •
Toshiba...
Answered
on Nov 27, 2009
Electronic
Warranty 1 year (from date of purchase)http://storage.toshiba.com/storagesolutions/pc-notebook/mkxx59gsm-series
Mk 2559 GSX
I have wipro laptop with thoshiba hdd.when i try to install windows it shows no hdd deteted.please help
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
Yesterday
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
